cgal-discuss - Re: [cgal-discuss] Re: About Bezier curves in Arrangement
  • To:
  • Subject: Re: [cgal-discuss] Re: About Bezier curves in Arrangement
  • Date: Fri, 11 Feb 2011 17:32:55 +0100
stzpz wrote:
Thanks so much, Sebastien. It's ok now.
Besides, why CGAL does not allow inserting bezier curve to an arrangement which control poionts are continually identical, just like 3 0 0 20 30 20 30?
I guess it should not be hard to fix this but can you motivate it?
Just by curiosity, are you also using bezier which are not segments? what is the application?
S.
Thanks!
Stzpz
2011/2/7 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email] </user/SendEmail.jtp?type=node&node=3301547&i=0>>
Hope the third try will be the good one.
S.
View this message in context: Re: About Bezier curves in Arrangement <http://cgal-discuss.949826.n4.nabble.com/About-Bezier-curves-in-Arrangement-tp3238384p3301547.html>
Sent from the cgal-discuss mailing list archive <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
