cgal-discuss - Re:Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement
  • To:
  • Subject: Re:Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement
  • Date: Sat, 12 Feb 2011 16:04:52 +0800 (CST)
在 2011-02-12,"碰碰" <> 写道:
At 2011-02-12,"碰碰" <> wrote:
At 2011-02-12,"Sebastien Loriot (GeometryFactory)" <> wrote: >stzpz wrote: >> Thanks so much, Sebastien. It's ok now. >>  >> Besides, why CGAL does not allow inserting bezier curve to an  >> arrangement which control poionts are continually identical, just like 3  >> 0 0 20 30 20 30? >>  >I guess it should not be hard to fix this but can you motivate it? > >Just by curiosity, are you also using bezier which are not segments?  >what is the application? > >S. > >> Thanks! >>    >> Stzpz >>  >>  >>  >> 2011/2/7 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden  >> email] </user/SendEmail.jtp?type=node&node=3301547&i=0>> >>  >>     Hope the third try will be the good one. >>  >>     S. >>  >>  >> ------------------------------------------------------------------------ >> View this message in context: Re: About Bezier curves in Arrangement  >> <http://cgal-discuss.949826.n4.nabble.com/About-Bezier-curves-in-Arrangement-tp3238384p3301547.html> >> Sent from the cgal-discuss mailing list archive  >> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com. > > >--  >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://lists-sop.inria.fr/wws/info/cgal-discuss >
