- To:
- Subject: Re:Re:Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement
- Date: Sat, 12 Feb 2011 17:48:33 +0800 (CST)
在 2011-02-12,"碰碰" <> 写道:
At 2011-02-12,"碰碰" <> wrote:
At 2011-02-12,"Sebastien Loriot (GeometryFactory)" <> wrote: >stzpz wrote: >> Thanks so much, Sebastien. It's ok now. >> >> Besides, why CGAL does not allow inserting bezier curve to an >> arrangement which control poionts are continually identical, just like 3 >> 0 0 20 30 20 30? >> >I guess it should not be hard to fix this but can you motivate it? > >Just by curiosity, are you also using bezier which are not segments? >what is the application? > >S. > >> Thanks! >> >> Stzpz >> >> >> >> 2011/2/7 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden >> email] </user/SendEmail.jtp?type=node&node=3301547&i=0>> >> >> Hope the third try will be the good one. >> >> S. >> >> >> ------------------------------------------------------------------------ >> View this message in context: Re: About Bezier curves in Arrangement >> <http://cgal-discuss.949826.n4.nabble.com/About-Bezier-curves-in-Arrangement-tp3238384p3301547.html> >> Sent from the cgal-discuss mailing list archive >> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com. > > >-- >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://lists-sop.inria.fr/wws/info/cgal-discuss >
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/01/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 02/03/2011
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/04/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 02/05/2011
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/07/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 02/11/2011
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/11/2011
- Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
- Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
- Re:Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
- Re:Re:Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
