- To:
- Subject: Re: [cgal-discuss] Re: Boolean set operation assertion
- Date: Tue, 22 Mar 2011 17:28:12 +0100
Le mardi 22 mars 2011 16:49:52, T.vanLankveld a écrit : > As I already said, this does fix the problem for that case, but makes the > rest of my code much too slow. The example given is heavily cut down from > my code to make as minimal example. > > My full code includes calculating Delaunay triangulations for two point > sets from which the polygons are extracted, and a number of tests on these > polygons, including some that require boolean set operations. You need to use CGAL::Exact_predicates_inexact_constructions_kernel for the triangulations, and then convert your data to the CGAL::Exact_predicates_exact_constructions_kernel to the the boolean operations. The class template CGAL::Cartesian_converter<K1, K2> can help to convert from a kernel to another. -- Laurent Rineau, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ Release Manager of the CGAL Project http://www.cgal.org/ |
- Re: [cgal-discuss] Re: Boolean set operation assertion, (continued)
- Re: [cgal-discuss] Re: Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Laurent Rineau (GeometryFactory), 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fulvio Mastrogiovanni, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Andreas Fabri, 03/22/2011
- [cgal-discuss] Re: Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Ben Supnik, 03/28/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Laurent Rineau (GeometryFactory), 03/22/2011
