- To:
- Subject: Re: [cgal-discuss] Probs loading .off file in mesh_3 demo
- Date: Tue, 22 Mar 2011 17:45:08 +0100
Le mardi 22 mars 2011 17:37:32, Fabio Casado Ruiz a écrit : > I'm trying to open camel.off with Mesh_3 demo (using ubuntu) and it just > says that it is not a known file format. Doesn't this demo take .off files > as an input?? help anyone? The .off file must be oriented. Try to open the same file with the Polyhedron_3 demo, and see if the type of the opened item is a polyhedron, or a polygons soup. In the polyhedron demo, there is a function to try to orient a polygons soup. -- Laurent Rineau, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ Release Manager of the CGAL Project http://www.cgal.org/ |
- [cgal-discuss] Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Re: Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Laurent Rineau (GeometryFactory), 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fulvio Mastrogiovanni, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Andreas Fabri, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Ben Supnik, 03/28/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Laurent Rineau (GeometryFactory), 03/22/2011
