- To:
- Subject: Re: [cgal-discuss] Re: Boolean set operation assertion
- Date: Sun, 27 Mar 2011 18:56:23 -0400
Hi,
Just my 0.02...you can approach the problem of precision vs. performance in 3 ways:
1. Use an inexact kernel and pray, as you have proposed.
2. Use something like a lazy kernel, as the CGAL developers have suggested. (BTW, I think that dev assert may indicate an uninitialized variable somewhere...it looks vaguely familiar to me.)
3. Rewrite your algorithms to take advantage of the things CGAL does well...when using exact algos and CGAL, the time complexity of the library is near ideal, but the constant factor for exact math is expensive.
I have tried all 3 of these for my own code, and can say from experience: if you're going to be working on your code for a while, choices 2 and 3 are preferable to 1.
The problem with 'working around' exact constructions is that it breaks the abstraction of the library - the library gives you a clean set of operations that 'always work', but it makes no guarantees about wen they 'sometimes work' for inexact math....thus it will be a lot harder to guarantee that the code works in all cases with technique 1.
cheers
Ben
T.vanLankveld wrote:
I have tried Exact_predicates_exact_kernel, in which case no errors occur,
but the program does become too slow.
However, I have found another way around the problem: these errors seem to
only occur when the polygons A and B share an edge. Therefore, before doing
a boolean operation, I remove each duplicate edge by creating a helper
polygon that covers the edge and subtracting it from A (I keep track the
part of the helper polygon that was part of polygon A).
an example for symmetric difference is:
void symmetric_difference(Polygon_set_2& A, const Polygon_set_2& B) {
Polygon_set_2 toRemove;
Arrangement_2 AA = A.arrangement();
for (Arrangement_2::Edge_iterator it = AA.edges_begin(); it !=
AA.edges_end(); ++it)
if (contains(B, *it)) {
Point_2 s = it->source()->point(), t =
it->target()->point();
Polygon_2 bar;
Vector_2 along(s, t);
along= 0.05 * (along/
CGAL::sqrt(along.squared_length()));
Vector_2 perp = along.perpendicular(CGAL::CLOCKWISE);
bar.push_back(s-along-perp);
bar.push_back(s-along+perp);
bar.push_back(t+along+perp);
bar.push_back(t+along-perp);
Polygon_set_2 rem(bar);
rem.difference(A);
rem.difference(B);
toRemove.join(rem);
A.join(bar);
A.symmetric_difference(B);
A.difference(toRemove);
Even though toRemove shares a number of edges with A^B, this does not
produce errors.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-set-operation-assertion-tp3396262p3397095.html
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://www.x-plane.com/blog/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Re: Boolean set operation assertion, (continued)
- [cgal-discuss] Re: Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Laurent Rineau (GeometryFactory), 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fulvio Mastrogiovanni, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Andreas Fabri, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Ben Supnik, 03/28/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Laurent Rineau (GeometryFactory), 03/22/2011
