- To:
- Subject: Re: [cgal-discuss] Probs loading .off file in mesh_3 demo
- Date: Tue, 22 Mar 2011 21:50:04 +0100
Hi Fulvio,
It is not really "cut in half". You can move the clipping plane,
and what you call "half" is the part of the mesh behind the
clipping plane. How else could you look inside.
andreas
On 22/03/2011 21:40, Fabio Casado Ruiz wrote:
Sorry to write once again but as an undergrad student our internet is
restricted and i have used all of this month quota downloading and
installing CGAL in both windows and linux. When I convert to
tetrahedral mesh using the Mesh_3 demo all the objects are cut in
half. Is this because of a configuration in the .off file, a
parametrization for the algorithm, or the demo itself?? Thanks.
Fabio ----- Original Message ----- From: "Fulvio
Mastrogiovanni"<>
To:
Sent: Tuesday, March 22, 2011
12:47:15 PM (GMT-0500) Auto-Detected Subject: Re: [cgal-discuss]
Dear Fabio,
I experienced this problem when loading huge off files (i.e., with
many triangles). Try to reduce them using any decimation algorithm.
Usually, any 3D graphics package has one.
Best,
Fulvio
On 22/03/2011 17:37, Fabio Casado Ruiz wrote:
I'm trying to open camel.off with Mesh_3 demo (using ubuntu) and it
just says that it is not a known file format. Doesn't this demo
take .off files as an input?? help anyone? thanks fabio.
- [cgal-discuss] Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Re: Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Laurent Rineau (GeometryFactory), 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fulvio Mastrogiovanni, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Andreas Fabri, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Ben Supnik, 03/28/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Laurent Rineau (GeometryFactory), 03/22/2011
