- To:
- Subject: Re: [cgal-discuss] Probs loading .off file in mesh_3 demo
- Date: Tue, 22 Mar 2011 16:05:38 -0400 (CDT)
Thanks. its all good now. I managed to play a little bit with the examples in
the demo/Polyhedron/data folder. Is there a way to load .stl files or how do
I create my own .off files? I designed a simple model (simple box) and I want
to be able to export it to some extension and then load it or convert it to
.off files. Is there a tutorial or demo for this?
----- Original Message -----
To:
Sent: Tuesday, March 22, 2011 12:45:08 PM (GMT-0500) Auto-Detected
Le mardi 22 mars 2011 17:37:32, Fabio Casado Ruiz a écrit :
> I'm trying to open camel.off with Mesh_3 demo (using ubuntu) and it just
> says that it is not a known file format. Doesn't this demo take .off files
> as an input?? help anyone?
The .off file must be oriented. Try to open the same file with the
Polyhedron_3 demo, and see if the type of the opened item is a polyhedron, or
a polygons soup. In the polyhedron demo, there is a function to try to orient
a polygons soup.
Laurent Rineau, PhD
- [cgal-discuss] Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Re: Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Laurent Rineau (GeometryFactory), 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fulvio Mastrogiovanni, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Andreas Fabri, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Ben Supnik, 03/28/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Laurent Rineau (GeometryFactory), 03/22/2011
