- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Wed, 18 May 2011 16:20:26 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=b38DOWUdFfWjl6eNoysczIK2pmB9VqcuVL2NQS8Z/Q9bXQEF0j43FYFxmf75mzzXUk 2cBzeqvzNrrdkWvbyNhaae5G6ahinrwB4avnk7JctE7xFlkNwKqj4UfJ7d5uItV95S2O dWGZL+tzwRAL0ndWOxx7v9Pfgtrx2fhu8gvb4=
Dear Sir
Thanks, I found it. My next question is about the CGAL configuration in CMAKE.
Could you pleas help?
I have visual c++ 2010 in my machine on windows 7.
I downlaoded both CGAL-3.8 Setup.exe and CMAKE-3.8
setup.exe. I installed both in my machine. According to
the installation guide, I need to configure CGAL using
CMAKE configure button. However, in CMAKE GUI,
there are two buttons to browse 'source' and browse
'build'. What folders should i select over there?
In the configuration, i chose generator as visual studio 10.
Brian.
On Wed, May 18, 2011 at 4:08 PM, Laurent Rineau (GeometryFactory) <> wrote:
On mercredi 18 mai 2011 16:53:21 Brian Sanjeewa Rupasinghe wrote:That is one purpose. You do not need to have access to the listing of of the
> Hi,
content of that directory.
Links to precompiled demos are in the right bar of this page:
The direct link to needed DLLs is:
Laurent Rineau, PhD
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Karstein Sørli, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
