cgal-discuss - Re: [cgal-discuss] Voronoi diagrams
  • To:
  • Subject: Re: [cgal-discuss] Voronoi diagrams
  • Date: Fri, 20 May 2011 11:14:54 +0200
Hello,
Your screenshot shows that it is CGAL-3.7
so this is inconsistent with
> I downlaoded both CGAL-3.8 Setup.exe
andreas
On 20/05/2011 11:09, Brian Sanjeewa Rupasinghe wrote:
Hi,
I installed CGAL and CMAKE with other libraries of Boost & QT according
to the
instructions given in the website below. I have Visual C++ 2008
Professional in
my computer on Windows 7. After configuring CMAKE to build libraries, it
gave
an error. Please see the attachment. Could you please help me to solve this.
Actually my requirement is to use the libraries of Traingulation and
Voronoi to
create my own clustering of point features. I need to implement in
Visual C++ 2008.
So, please help me.
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
Brian.
On Wed, May 18, 2011 at 5:45 PM, Sebastien Loriot (GeometryFactory)
Dear Sir
Thanks, I found it. My next question is about the CGAL
configuration in CMAKE.
Could you pleas help?
I have visual c++ 2010 in my machine on windows 7.
I downlaoded both CGAL-3.8 Setup.exe and CMAKE-3.8
setup.exe. I installed both in my machine. According to
the installation guide, I need to configure CGAL using
CMAKE configure button. However, in CMAKE GUI,
there are two buttons to browse 'source' and browse
Using Google I found that in 'source' you should indicate the path
containing the CMakeLists.txt (the root of CGAL)
and in 'build' the path where the lib will be compiled. It can be
either the root of CGAL if you want to do an in-source build or whatever
directory you want (out-source build). The second approach is better if
you want ot use several version of the lib.
S.
'build'. What folders should i select over there? In the
configuration, i chose generator as visual studio 10.
Brian.
On Wed, May 18, 2011 at 4:08 PM, Laurent Rineau
(GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>
wrote:
On mercredi 18 mai 2011 16:53:21 Brian Sanjeewa Rupasinghe
wrote:
> Hi,
> I cannot access www.cgal.org/demo <http://www.cgal.org/demo>
<http://www.cgal.org/demo>. Why?
That is one purpose. You do not need to have access to the
listing
of of the
content of that directory.
Links to precompiled demos are in the right bar of this page:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/packages.html
The direct link to needed DLLs is:
http://www.cgal.org/demo/3.8/CGAL-demoDLLs.zip
Laurent Rineau, PhD
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
