- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Wed, 18 May 2011 17:03:58 +0200
Brian Sanjeewa Rupasinghe wrote:
Hi,http://www.cgal.org/demo/3.8/CGAL-demoDLLs.zip
Could you please send the link to site to select one as you say (In the left side of "Installation", see the link named "dlls ).
On Wed, May 18, 2011 at 3:35 PM, Laurent Rineau (GeometryFactory) < <mailto:>> wrote:
On mercredi 18 mai 2011 16:25:24 Sebastien Loriot (GeometryFactory)
> > Hi,
> > Thanks. I tried installing the demo you sent. When i tried to
setup it,
> > it gives an error message "QtGui4.dll is missing"
> See
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_inst
> allation_manual.html#Subsection_4.11
Actually, for precompiled demos, you need to download the DLLs. See
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/packages.html#part_I
In the left side of "Installation", see the link named "dlls used by all
demos". And download that zip. You must put those DLLs somewhere in
your PATH.
The easiest way it to put them in the same directory as the demos'
.exe files.
Laurent Rineau, PhD
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
