- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Fri, 20 May 2011 17:10:54 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=lCwp4bEIACQm41TyKGpQ6ip5ZRAirT/1UX2aGIa3HJhZNowIOSWCqA0mxguYMY1BJO necM+LYsOYQZ5wCH9SI2vdZLkFHhmXlWc+lqmyNlbBNliiT0iYeKbaPQwVSiRdWoJSMl OgyGuWfrNrr+D4m/zBKxnd2IYvGKgo6fng4xw=
Sir,
Extremely sorry if i troubled you. After configuring CGAL with
CMAKE, I generated the Projects. This error occured when
i tried to build one of the projects; actually Triangulation_2
project.
Thanks again.
Brian.
On Fri, May 20, 2011 at 5:03 PM, Laurent Rineau (GeometryFactory) <> wrote:
On vendredi 20 mai 2011 17:54:13 Sebastien Loriot (GeometryFactory) wrote:To compile it *twice*: once in Release mode, and once in Debug mode (that is
> Andreas already told you to check that when you configured the lib CGAL
> with cmake, you then need to compile it (which will generate the file
> you are missing).
an option of the Visual Studio GUI).
I agree.
> Also please stop sending reminders, this thread is already long enough.
Laurent Rineau, PhD
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
