- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Wed, 18 May 2011 17:36:08 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=LSDVaEhynAwIYpRs2EbMCiIdLk2bSlWLFVbGHcFNXeUtLFpRr6lRMlF8tvzfjN0awn BfOqRzjPoqYrwZOX6a/QwI9KOQYyoqbiQ+CjmENSAkYwmwOXALnoO3/alKElxRof8ADz oNOwdkW4snfcc77s+kmhNmrEJkgMzumBGXIxg=
Hi,
Thanks. Demo worked nicely. However, what i need is to write code in Visual C++ 2010
using CGAL libraries. In oder to do that is it required to configure CGAL example code
into Visual Studio 10?
Brian.
On Wed, May 18, 2011 at 4:08 PM, Laurent Rineau (GeometryFactory) <> wrote:
On mercredi 18 mai 2011 16:53:21 Brian Sanjeewa Rupasinghe wrote:That is one purpose. You do not need to have access to the listing of of the
> Hi,
content of that directory.
Links to precompiled demos are in the right bar of this page:
The direct link to needed DLLs is:
Laurent Rineau, PhD
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
