- To:
- Subject: Re: [cgal-discuss] Alpha_shape_2 with info
- Date: Thu, 19 May 2011 16:35:44 +0200
I added this constructor in the attached file.
Alpha_shape_2(Dt& dt,
const Coord_type& alpha = Coord_type(0),
Mode m = GENERAL)
Note that as in 3D, after the construction of the alpha-shape,
the triangulation can no longer be used.
Have a look here for adding information:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_35.11.2
S.
Mariette Yvinec wrote:
I see ...
In 3D you may construct the Alpha_shape from the Triangulation
so that you can enter your vertices wih their info
in the triangulation and then build the Alpha_shape from the triangulation.
In 2D, such a constructor does not seem to exist.
Obviously, we should add it.
Regards,
Mariette
Le 19/05/11 15:52, Asher Kamiraze a écrit :
Hi,
2011/5/19 Mariette Yvinec < <mailto:>>
push_back should be private too.
Yes, that's what I thought.
If you use push_back,
the triangulation will be updated but not the alpha_shapes...
I don't see any problem in what you propose.
Since I can use neither push_back nor insert, how can I attach info to a vertex?
If it is a triangulation, I add a point and get the returned vertex, then attach the info on it. With alpha shapes, I have to give as input a range of points, and do not know how to attach info of the resulting vertices.
Regards,
Asher
Le 19/05/11 12:46, Asher Kamiraze a écrit :
Hi all,
Is there a way to build an alpha_shape_2 with info? Something
similar to a triangulation with info.
I have also noticed that insert() is private in alpha_shape_2,
but, push_back is not. Isn't it a problem?
Here is what I am trying to do:
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
struct vertex_info { Point point3d; };
struct face_info {};
typedef
CGAL::Triangulation_vertex_base_with_info_2<vertex_info,K> Vb_2;
typedef
CGAL::Constrained_triangulation_face_base_with_info_2<face_info,K>
Fb_2;
typedef CGAL::Alpha_shape_vertex_base_2<K, Vb_2> Vb;
typedef CGAL::Alpha_shape_face_base_2<K, Fb_2> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> TDS_2;
typedef CGAL::Delaunay_triangulation_2<K , TDS_2> DT_2;
typedef CGAL::Alpha_shape_2<DT_2> Alpha_shape_2;
Alpha_shape_2 alpha_shape(0.5);
// How to insert points in alpha_shape with
attached info?
Hope you could help
Best regards
Asher
-- Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
-- You are currently subscribed to cgal-discuss.
Mariette Yvinec
// Copyright (c) 1997 INRIA Sophia-Antipolis (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/trunk/Alpha_shapes_2/include/CGAL/Alpha_shape_2.h $ // $Id: Alpha_shape_2.h 58105 2010-08-17 07:25:59Z sloriot $ // // // Author(s) : Tran Kai Frank DA // Andreas Fabri <> #ifndef CGAL_ALPHA_SHAPE_2_H #define CGAL_ALPHA_SHAPE_2_H #include <CGAL/basic.h> #include <list> #include <set> #include <map> #include <vector> #include <algorithm> #include <utility> #include <iostream> #include <CGAL/utility.h> #include <CGAL/Unique_hash_map.h> #include <CGAL/Triangulation_vertex_base_2.h> #include <CGAL/Triangulation_face_base_2.h> #include <CGAL/Alpha_shape_vertex_base_2.h> #include <CGAL/Alpha_shape_face_base_2.h> namespace CGAL { template < class Dt > class Alpha_shape_2 : public Dt { // DEFINITION The class Alpha_shape_2<Dt> represents the family // of alpha-shapes of points in a plane for all positive alpha. It // maintains the underlying Delaunay triangulation which represents // connectivity and order among its faces. Each k-dimensional face of the // Delaunay triangulation is associated with an interval that specifies // for which values of alpha the face belongs to the alpha-shape (sorted // linear arrays resp. multimaps or interval trees). There are links // between the intervals and the k-dimensional faces of the Delaunay // triangulation (multimaps resp. std::hashtables). // //------------------------- TYPES ------------------------------------ public: typedef typename Dt::Geom_traits Gt; typedef typename Dt::Triangulation_data_structure Tds; typedef typename Gt::FT Coord_type; typedef typename Gt::FT NT; typedef typename Gt::FT FT; typedef typename Gt::Point_2 Point; typedef typename Gt::Segment_2 Segment; typedef typename Gt::Ray_2 Ray; typedef typename Gt::Line_2 Line; typedef typename Dt::Face_handle Face_handle; typedef typename Dt::Vertex_handle Vertex_handle; typedef typename Dt::Edge Edge; typedef typename Dt::Face_circulator Face_circulator; typedef typename Dt::Edge_circulator Edge_circulator; typedef typename Dt::Vertex_circulator Vertex_circulator; typedef typename Dt::Finite_faces_iterator Finite_faces_iterator; typedef typename Dt::Edge_iterator Edge_iterator; typedef typename Dt::Finite_vertices_iterator Finite_vertices_iterator; typedef typename Dt::Locate_type Locate_type; typedef typename Dt::size_type size_type; using Dt::finite_vertices_begin; using Dt::finite_vertices_end; using Dt::faces_begin; using Dt::faces_end; using Dt::edges_begin; using Dt::edges_end; using Dt::number_of_vertices; using Dt::cw; using Dt::ccw; using Dt::VERTEX; using Dt::EDGE; using Dt::FACE; using Dt::OUTSIDE_CONVEX_HULL; using Dt::OUTSIDE_AFFINE_HULL; using Dt::dimension; using Dt::is_infinite; // for backward compatibility typedef Finite_vertices_iterator Vertex_iterator; typedef Finite_faces_iterator Face_iterator; private: typedef std::multimap< Coord_type, Face_handle > Interval_face_map; typedef typename Interval_face_map::value_type Interval_face; typedef typename Tds::Face::Interval_3 Interval3; typedef std::multimap< Interval3, Edge > Interval_edge_map; typedef typename Interval_edge_map::value_type Interval_edge; typedef std::pair< Coord_type, Coord_type > Interval2; typedef std::multimap< Interval2, Vertex_handle > Interval_vertex_map; typedef typename Interval_vertex_map::value_type Interval_vertex; typedef Face_handle const const_void; typedef std::pair<const_void, int> const_Edge; typedef std::vector< Coord_type > Alpha_spectrum; typedef std::vector< Segment > Vect_seg; typedef Unique_hash_map< Face_handle, bool > Marked_face_set; public: typedef typename std::list< Vertex_handle >::iterator Alpha_shape_vertices_iterator; typedef typename std::list< Edge >::iterator Alpha_shape_edges_iterator; typedef typename Alpha_spectrum::const_iterator Alpha_iterator; // An iterator that allow to traverse the sorted sequence of // different alpha-values. The iterator is bidirectional and // non-mutable. Its value-type is Coord_type enum Classification_type {EXTERIOR, SINGULAR, REGULAR, INTERIOR}; // Distinguishes the different cases for classifying a // k-dimensional face of the underlying Delaunay triangulation of // the alpha-shape. // // `EXTERIOR' if the face does not belong to the alpha-complex. // // `SINGULAR' if the face belongs to the boundary of the // alpha-shape, but is not incident to any higher-dimensional // face of the alpha-complex // // `REGULAR' if face belongs to the boundary of the alpha-shape // and is incident to a higher-dimensional face of the // alpha-complex // // `INTERIOR' if the face belongs to the alpha-complex, but does // not belong to the boundary of the alpha-shape enum Mode {GENERAL, REGULARIZED}; // In general, an alpha shape is a non-connected, mixed-dimension // polygon. Its regularized version is formed by the set of // regular edges and their vertices //------------------------ private VARIABLES ------------------------- private: // only finite edges and faces are inserted into the maps Interval_face_map _interval_face_map; Interval_edge_map _interval_edge_map; Interval_vertex_map _interval_vertex_map; Alpha_spectrum _alpha_spectrum; Coord_type _alpha; Mode _mode; // should be constants Coord_type Infinity; Coord_type UNDEFINED; mutable std::list< Vertex_handle > Alpha_shape_vertices_list; mutable std::list< Edge > Alpha_shape_edges_list; mutable bool use_vertex_cache; mutable bool use_edge_cache; public: //------------------------- CONSTRUCTORS ------------------------------ // Introduces an empty alpha-shape `A' for a positive // alpha-value `alpha'. Precondition: `alpha' >= 0. Alpha_shape_2(Coord_type alpha = Coord_type(0), Mode m = GENERAL) : _alpha(alpha), _mode(m), Infinity(-1), UNDEFINED(-2), use_vertex_cache(false), use_edge_cache(false) {} // Introduces an alpha-shape `A' for a positive alpha-value // `alpha' that is initialized with the points in the range // from first to last template <class InputIterator> Alpha_shape_2(const InputIterator& first, const InputIterator& last, const Coord_type& alpha = Coord_type(0), Mode m = GENERAL) : _alpha(alpha), _mode(m), Infinity(-1), UNDEFINED(-2) , use_vertex_cache(false), use_edge_cache(false) { Dt::insert(first, last); if (dimension() == 2) { // Compute the associated _interval_face_map initialize_interval_face_map(); // Compute the associated _interval_edge_map initialize_interval_edge_map(); // Compute the associated _interval_vertex_map initialize_interval_vertex_map(); // merge the two maps initialize_alpha_spectrum(); } } // Introduces an alpha-shape `A' for a positive alpha-value // `alpha' that is initialized with the triangulation Alpha_shape_2(Dt& dt, const Coord_type& alpha = Coord_type(0), Mode m = GENERAL) : _alpha(alpha), _mode(m), Infinity(-1), UNDEFINED(-2) , use_vertex_cache(false), use_edge_cache(false) { Dt::swap(dt); if (dimension() == 2) { // Compute the associated _interval_face_map initialize_interval_face_map(); // Compute the associated _interval_edge_map initialize_interval_edge_map(); // Compute the associated _interval_vertex_map initialize_interval_vertex_map(); // merge the two maps initialize_alpha_spectrum(); } } public: //----------- OUTPUT POINTS CONNECTED BY PAIRS ---------------------- std::list<Point> Output(); std::ostream& op_ostream(std::ostream& os) const; //----------------------- OPERATIONS --------------------------------- // Introduces an alpha-shape `A' for a positive alpha-value // `alpha' that is initialized with the points in the range // from first to last template < class InputIterator > std::ptrdiff_t make_alpha_shape(const InputIterator& first, const InputIterator& last) { clear(); size_type n = Dt::insert(first, last); if (dimension() == 2) { // Compute the associated _interval_face_map initialize_interval_face_map(); // Compute the associated _interval_edge_map initialize_interval_edge_map(); // Compute the associated _interval_vertex_map initialize_interval_vertex_map(); // merge the two maps initialize_alpha_spectrum(); } return n; } private : //--------------------- INITIALIZATION OF PRIVATE MEMBERS ----------- void initialize_interval_face_map(); void initialize_interval_edge_map(); void initialize_interval_vertex_map(); void initialize_alpha_spectrum(); //--------------------------------------------------------------------- public: void clear() { // clears the structure Dt::clear(); _interval_face_map.clear(); _interval_edge_map.clear(); _interval_vertex_map.clear(); _alpha_spectrum.clear(); Alpha_shape_vertices_list.clear(); Alpha_shape_edges_list.clear(); set_alpha(Coord_type(0)); set_mode(GENERAL); } //----------------------- PRIVATE MEMBERS -------------------------- private: struct Less { bool operator()(const Interval_edge& ie, const Coord_type& alpha) { return ie.first.first < alpha; } bool operator()( const Coord_type& alpha, const Interval_edge& ie) { return alpha < ie.first.first; } // Needed for STL implementations of upper_bound which in debug mode // check sortedness of range bool operator()(const Interval_edge& ie, const Interval_edge& ie2) const { return ie < ie2; } }; //----------------------- ACCESS TO PRIVATE MEMBERS ----------------- private: Coord_type find_interval(const Face_handle& f) const { return f->get_alpha(); // return the value Alpha f the face f } Interval3 find_interval(const_Edge e) const { // corriger le parametrage return (e.first)->get_ranges(e.second); // return the Interval3 for the edge n } //--------------------------------------------------------------------- public: Coord_type set_alpha(const Coord_type& alpha) { // Sets the alpha-value to `alpha'. Precondition: `alpha' >= 0. // Returns the previous alpha Coord_type previous_alpha = _alpha; _alpha = alpha; use_vertex_cache = false; use_edge_cache = false; return previous_alpha; } const Coord_type& get_alpha() const { // Returns the current alpha-value. return _alpha; } const Coord_type& get_nth_alpha(size_type n) const { // Returns the n-th alpha-value. // n < size() if (! _alpha_spectrum.empty()) return _alpha_spectrum[n]; else return UNDEFINED; } size_type number_of_alphas() const { // Returns the number of not necessary different alpha-values return _alpha_spectrum.size(); } //--------------------------------------------------------------------- private: // the dynamic version is not yet implemented // desactivate the triangulation member functions Vertex_handle insert(const Point& p); // Inserts point `p' in the alpha shape and returns the // corresponding vertex of the underlying Delaunay triangulation. // If point `p' coincides with an already existing vertex, this // vertex is returned and the alpha shape remains unchanged. // Otherwise, the vertex is inserted in the underlying Delaunay // triangulation and the associated intervals are updated. void remove(Vertex_handle v); // Removes the vertex from the underlying Delaunay triangulation. // The created hole is retriangulated and the associated intervals // are updated. //--------------------------------------------------------------------- public: Mode set_mode(Mode mode = GENERAL ) { // Sets `A' to its general or regularized version. Returns the // previous mode. Mode previous_mode = _mode; _mode = mode; return previous_mode; } Mode get_mode() const { // Returns whether `A' is general or regularized. return _mode; } //--------------------------------------------------------------------- private: void update_alpha_shape_vertex_list()const; //--------------------------------------------------------------------- void update_alpha_shape_edges_list() const; //--------------------------------------------------------------------- public: Alpha_shape_vertices_iterator alpha_shape_vertices_begin() const { if(!use_vertex_cache){ update_alpha_shape_vertex_list(); } return Alpha_shape_vertices_list.begin(); } // for backward compatibility Alpha_shape_vertices_iterator Alpha_shape_vertices_begin() { return alpha_shape_vertices_begin(); } //--------------------------------------------------------------------- Alpha_shape_vertices_iterator alpha_shape_vertices_end() const { return Alpha_shape_vertices_list.end(); } Alpha_shape_vertices_iterator Alpha_shape_vertices_end() const { return Alpha_shape_vertices_list.end(); } //--------------------------------------------------------------------- Alpha_shape_edges_iterator alpha_shape_edges_begin() const { if(!use_edge_cache){ update_alpha_shape_edges_list(); } return Alpha_shape_edges_list.begin(); } Alpha_shape_edges_iterator Alpha_shape_edges_begin() const { return alpha_shape_edges_begin(); } //--------------------------------------------------------------------- Alpha_shape_edges_iterator alpha_shape_edges_end() const { return Alpha_shape_edges_list.end(); } Alpha_shape_edges_iterator Alpha_shape_edges_end() const { return Alpha_shape_edges_list.end(); } public: // Traversal of the alpha-Values // // The alpha shape class defines an iterator that allows to // visit the sorted sequence of alpha-values. This iterator is // non-mutable and bidirectional. Its value type is Coord_type. Alpha_iterator alpha_begin() const { // Returns an iterator that allows to traverse the sorted sequence // of alpha-values of `A'. return _alpha_spectrum.begin(); } Alpha_iterator alpha_end() const { // Returns the corresponding past-the-end iterator. return _alpha_spectrum.end(); } Alpha_iterator alpha_find(const Coord_type& alpha) const { // Returns an iterator pointing to an element with alpha-value // `alpha', or the corresponding past-the-end iterator if such an // element is not found. return std::find(_alpha_spectrum.begin(), _alpha_spectrum.end(), alpha); } Alpha_iterator alpha_lower_bound(const Coord_type& alpha) const { // Returns an iterator pointing to the first element with // alpha-value not less than `alpha'. return std::lower_bound(_alpha_spectrum.begin(), _alpha_spectrum.end(), alpha); } Alpha_iterator alpha_upper_bound(const Coord_type& alpha) const { // Returns an iterator pointing to the first element with // alpha-value greater than `alpha'. return std::upper_bound(_alpha_spectrum.begin(), _alpha_spectrum.end(), alpha); } //--------------------- PREDICATES ----------------------------------- // the classification predicates take // amortized const time if STL_STD::HASH_TABLES // O(log #alpha_shape ) otherwise Classification_type classify(const Point& p ) const { return classify( p, get_alpha()); } Classification_type classify(const Point& p, const Coord_type& alpha) const { // Classifies a point `p' with respect to `A'. Locate_type type; int i; Face_handle pFace = locate(p, type, i); switch (type) { case VERTEX : return classify(pFace->vertex(i), alpha); case EDGE : return classify(pFace, i, alpha); case FACE : return classify(pFace, alpha); case OUTSIDE_CONVEX_HULL : case OUTSIDE_AFFINE_HULL : return EXTERIOR; default : return EXTERIOR; } } //--------------------------------------------------------------------- Classification_type classify(const Face_handle& f) const { // Classifies the face `f' of the underlying Delaunay // triangulation with respect to `A'. return classify(f, get_alpha()); } Classification_type classify(const Face_handle& f, const Coord_type& alpha) const { // Classifies the face `f' of the underlying Delaunay // triangulation with respect to `A'. // we consider close circles : // f->radius < alpha <=> f exterior // problem the operator [] is non-const if (is_infinite(f)) return EXTERIOR; // the version that computes the squared radius seems to be // much faster return (find_interval(f) <= alpha) ? INTERIOR : EXTERIOR; } //--------------------------------------------------------------------- Classification_type classify(const Edge& edge) const { return classify(edge.first, edge.second, get_alpha()); } Classification_type classify(const Face_handle& f, int i) const { return classify(f, i, get_alpha()); } Classification_type classify(const Edge& edge, const Coord_type& alpha) const { return classify(edge.first, edge.second, alpha); } Classification_type classify(const Face_handle& f, int i, const Coord_type& alpha) const; //--------------------------------------------------------------------- Classification_type classify(const Vertex_handle& v) const { return classify(v, get_alpha()); } Classification_type classify(const Vertex_handle& v, const Coord_type& alpha) const; //--------------------- NB COMPONENTS --------------------------------- int number_solid_components() const { return number_of_solid_components(get_alpha()); } int number_of_solid_components() const { return number_of_solid_components(get_alpha()); } size_type number_solid_components(const Coord_type& alpha) const { return number_of_solid_components(get_alpha()); } size_type number_of_solid_components(const Coord_type& alpha) const; private: void traverse(const Face_handle& pFace, Marked_face_set& marked_face_set, const Coord_type alpha) const; // class Line_face_circulator; //---------------------------------------------------------------------- public: Alpha_iterator find_optimal_alpha(size_type nb_components); private: Coord_type find_alpha_solid() const; //---------------------- PREDICATES ------------------------------------ private: bool is_attached(const Face_handle& f, int i) const { Bounded_side b = Gt().side_of_bounded_circle_2_object()(f->vertex(cw(i))->point(), f->vertex(ccw(i))->point(), f->vertex(i)->point()); return (b == ON_BOUNDED_SIDE) ? true : false; } //-------------------- GEOMETRIC PRIMITIVES ---------------------------- Coord_type squared_radius(const Face_handle& f) const { return Gt().compute_squared_radius_2_object()(f->vertex(0)->point(), f->vertex(1)->point(), f->vertex(2)->point()); } Coord_type squared_radius(const Face_handle& f, int i) const { return Gt().compute_squared_radius_2_object()(f->vertex(ccw(i))->point(), f->vertex(cw(i))->point()); } //--------------------------------------------------------------------- private: // prevent default copy constructor and default assigment Alpha_shape_2(const Alpha_shape_2& A); Alpha_shape_2& operator=(const Alpha_shape_2& A); public: // to debug void print_edge_map(); }; //--------------------------------------------------------------------- //----------------------- MEMBER FUNCTIONS ----------------------------- //--------------------------------------------------------------------- template < class Dt > void Alpha_shape_2<Dt>::initialize_interval_face_map() { Coord_type alpha_f; // only finite faces for(Finite_faces_iterator face_it = faces_begin(); face_it != faces_end(); ++face_it) { alpha_f = squared_radius(face_it); _interval_face_map.insert(Interval_face(alpha_f, face_it)); // cross references face_it->set_alpha(alpha_f); } } //------------------------------------------------------------------------- template < class Dt > void Alpha_shape_2<Dt>::initialize_interval_edge_map() { Edge_iterator edge_it; Edge edge; // only finite faces for( edge_it = edges_begin(); edge_it != edges_end(); ++edge_it) { Interval3 interval; edge = (*edge_it); Face_handle pFace = edge.first; int i = edge.second; Face_handle pNeighbor = pFace->neighbor(i); int Neigh_i = pNeighbor->index(pFace); // not on the convex hull if(!is_infinite(pFace) && !is_infinite(pNeighbor)) { Coord_type squared_radius_Face = find_interval(pFace); Coord_type squared_radius_Neighbor = find_interval(pNeighbor); if (squared_radius_Neighbor < squared_radius_Face) { edge = Edge(pNeighbor, Neigh_i); Coord_type coord_tmp = squared_radius_Face; squared_radius_Face = squared_radius_Neighbor; squared_radius_Neighbor = coord_tmp; } interval = (is_attached(pFace, i) || is_attached(pNeighbor, Neigh_i)) ? make_triple(UNDEFINED, squared_radius_Face, squared_radius_Neighbor): make_triple(squared_radius(pFace, i), squared_radius_Face, squared_radius_Neighbor); } else { // on the convex hull if(is_infinite(pFace)) { if (!is_infinite(pNeighbor)) { interval = (is_attached(pNeighbor, Neigh_i)) ? make_triple(UNDEFINED, find_interval(pNeighbor), Infinity): make_triple(squared_radius(pNeighbor, Neigh_i), find_interval(pNeighbor), Infinity); edge = Edge(pNeighbor, Neigh_i); } else { // both faces are infinite by definition unattached // the edge is finite by construction CGAL_triangulation_precondition((is_infinite(pNeighbor) && is_infinite(pFace))); interval = make_triple(squared_radius(pFace, i), Infinity, Infinity); } } else { // is_infinite(pNeighbor) CGAL_triangulation_precondition((is_infinite(pNeighbor) && !is_infinite(pFace))); if (is_attached(pFace, i)) interval = make_triple(UNDEFINED, find_interval(pFace), Infinity); else interval = make_triple(squared_radius(pFace, i), find_interval(pFace), Infinity); } } _interval_edge_map.insert(Interval_edge(interval, edge)); // cross-links (edge.first)->set_ranges(edge.second,interval); // MY : to fix a bug I store the interval of the edge in both faces Face_handle neighbor = (edge.first)->neighbor(edge.second); int ni = neighbor->index(edge.first); neighbor->set_ranges( ni, interval); } // Remark: // The interval_edge_map will be sorted as follows // first the attached edges on the convex hull // second not on the convex hull // third the un-attached edges on the convex hull // finally not on the convex hull // // if we are in regularized mode we should sort differently // by the second third first Key } //------------------------------------------------------------------------- template < class Dt > void Alpha_shape_2<Dt>::initialize_interval_vertex_map() { Coord_type alpha_mid_v; Coord_type alpha_max_v; Coord_type alpha_f; Finite_vertices_iterator vertex_it; for( vertex_it = finite_vertices_begin(); vertex_it != finite_vertices_end(); ++vertex_it) { Vertex_handle v = vertex_it; Face_handle f; alpha_max_v = Coord_type(0); alpha_mid_v = (!_interval_face_map.empty() ? (--_interval_face_map.end())->first : Coord_type(0)); //----------------- examine incident edges -------------------------- // // if we used Edelsbrunner and Muecke's definition // // singular means not incident to any higher-dimensional face // // regular means incident to a higher-dimensional face // Edge_circulator edge_circ = this->incident_edges(v), // edge_done(edge_circ); // do // { // f = (*edge_circ).first; // int i = (*edge_circ).second; // if (is_infinite(f, i)) // { // alpha_max_v = Infinity; // } // else // { // Interval3 interval3 = find_interval(const_Edge(f, i)); // alpha_mid_v = (interval3.first != UNDEFINED) ? // CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_mid_v, interval3.first): // CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_mid_v, interval3.second); // if (alpha_max_v != Infinity) // { // alpha_max_v = (interval3.third != Infinity) ? // CGAL::max BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_max_v, interval3.third): // Infinity; // } // } // } // while(++edge_circ != edge_done); //-------------- examine incident faces -------------------------- // we use a different definition than Edelsbrunner and Muecke // singular means not incident to any 2-dimensional face // regular means incident to a 2-dimensional face Face_circulator face_circ = this->incident_faces(v), done = face_circ; if (!face_circ.is_empty()) { do { f = face_circ; if (is_infinite(f)) { alpha_max_v = Infinity; // continue; } else { alpha_f = find_interval(f); // if we define singular as not incident to a 2-dimensional // face alpha_mid_v = CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_mid_v, alpha_f); if (alpha_max_v != Infinity) alpha_max_v = CGAL::max BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_max_v, alpha_f); } } while(++face_circ != done); } Interval2 interval = std::make_pair(alpha_mid_v, alpha_max_v); _interval_vertex_map.insert(Interval_vertex(interval, vertex_it)); // cross references vertex_it->set_range(interval); } } //------------------------------------------------------------------------- template < class Dt > void Alpha_shape_2<Dt>::initialize_alpha_spectrum() { // skip the attached edges // <=> _interval_edge_map.first.first == UNDEFINED typename Interval_edge_map::iterator edge_it = std::upper_bound(_interval_edge_map.begin(), _interval_edge_map.end(), UNDEFINED, Less()); // merge the maps which is sorted and contains the alpha-values // of the unattached edges and the triangles. // eliminate duplicate values due to for example attached edges // merge and copy from STL since assignment should be function object typename Interval_face_map::iterator face_it = _interval_face_map.begin(); _alpha_spectrum.reserve(_interval_face_map.size() + _interval_edge_map.size()/ 2 ); // should be only the number of unattached edges // size_type nb_unattached_edges; // distance(edge_it, _interval_edge_map.end(), nb_unattached_edges); // however the distance function is expensive while (edge_it != _interval_edge_map.end() || face_it != _interval_face_map.end()) { if (face_it != _interval_face_map.end() && (edge_it == _interval_edge_map.end() || ((*face_it).first < (*edge_it).first.first))) { if (((_alpha_spectrum.empty() || _alpha_spectrum.back() < (*face_it).first)) && ((*face_it).first > Coord_type(0))) _alpha_spectrum.push_back((*face_it).first); face_it++; } else { if (((_alpha_spectrum.empty() || _alpha_spectrum.back() < (*edge_it).first.first)) && (((*edge_it).first.first) > Coord_type(0))) _alpha_spectrum.push_back((*edge_it).first.first); edge_it++; } } while (edge_it != _interval_edge_map.end()) { if (((_alpha_spectrum.empty() || _alpha_spectrum.back() < (*edge_it).first.first))&& (((*edge_it).first.first) > Coord_type(0))) _alpha_spectrum.push_back((*edge_it).first.first); edge_it++; } while (face_it != _interval_face_map.end()) { if (((_alpha_spectrum.empty() || _alpha_spectrum.back() < (*face_it).first))&& ((*face_it).first > Coord_type(0))) _alpha_spectrum.push_back((*face_it).first); face_it++; } } //------------------------------------------------------------------------- template < class Dt > void Alpha_shape_2<Dt>::update_alpha_shape_vertex_list()const { //typedef typename Alpha_shape_2<Dt>::Interval_vertex_map // Interval_vertex_map; typename Interval_vertex_map::const_iterator vertex_alpha_it; //const typename Alpha_shape_2<Dt>::Interval2* pInterval2; const Interval2* pInterval2; Vertex_handle v; Alpha_shape_vertices_list.clear(); // write the regular vertices for (vertex_alpha_it = _interval_vertex_map.begin(); vertex_alpha_it != _interval_vertex_map.end() && (*vertex_alpha_it).first.first <= get_alpha(); ++vertex_alpha_it) { pInterval2 = &(*vertex_alpha_it).first; if((pInterval2->second > get_alpha() || pInterval2->second == Infinity)) { // alpha must be larger than the min boundary // and alpha is smaller than the upper boundary // which might be infinity // write the vertex v = (*vertex_alpha_it).second; CGAL_triangulation_assertion((classify(v) == REGULAR)); Alpha_shape_vertices_list.push_back(v); } } if (get_mode() == Alpha_shape_2<Dt>::GENERAL) { // write the singular vertices for (; vertex_alpha_it != _interval_vertex_map.end(); ++vertex_alpha_it) { v = (*vertex_alpha_it).second; CGAL_triangulation_assertion((classify(v) == SINGULAR)); Alpha_shape_vertices_list.push_back(v); } } use_vertex_cache = true; } //------------------------------------------------------------------------- template < class Dt > void Alpha_shape_2<Dt>::update_alpha_shape_edges_list() const { // Writes the edges of the alpha shape `A' for the current $\alpha$-value // to the container where 'out' refers to. Returns an output iterator // which is the end of the constructed range. //typedef typename Alpha_shape_2<Dt>::Interval_edge_map Interval_edge_map; typename Interval_edge_map::const_iterator edge_alpha_it; //const typename Alpha_shape_2<Dt>::Interval3* pInterval; const Interval3* pInterval; Alpha_shape_edges_list.clear(); if (get_mode() == REGULARIZED) { // it is much faster looking at the sorted intervals // than looking at all sorted faces // alpha must be larger than the mid boundary // and alpha is smaller than the upper boundary for (edge_alpha_it = _interval_edge_map.begin(); edge_alpha_it != _interval_edge_map.end() && (*edge_alpha_it).first.first <= get_alpha(); ++edge_alpha_it) { pInterval = &(*edge_alpha_it).first; CGAL_triangulation_assertion(pInterval->second != Infinity); // since this happens only for convex hull of dimension 2 // thus singular if(pInterval->second <= get_alpha() && (pInterval->third > get_alpha() || pInterval->third == Infinity)) { // alpha must be larger than the mid boundary // and alpha is smaller than the upper boundary // which might be infinity // visualize the boundary CGAL_triangulation_assertion((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR)); Alpha_shape_edges_list.push_back(Edge((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)); } } } else { // get_mode() == GENERAL ------------------------------------------- // draw the edges for (edge_alpha_it = _interval_edge_map.begin(); edge_alpha_it != _interval_edge_map.end() && (*edge_alpha_it).first.first <= get_alpha(); ++edge_alpha_it) { pInterval = &(*edge_alpha_it).first; if (pInterval->first == UNDEFINED) { CGAL_triangulation_assertion(pInterval->second != Infinity); // since this happens only for convex hull of dimension 2 // thus singular if(pInterval->second <= get_alpha() && (pInterval->third > get_alpha() || pInterval->third == Infinity)) { // alpha must be larger than the mid boundary // and alpha is smaller than the upper boundary // which might be infinity // visualize the boundary CGAL_triangulation_assertion((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR)); Alpha_shape_edges_list.push_back(Edge((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)); } } else { if(pInterval->third > get_alpha() || pInterval->third == Infinity) { // if alpha is smaller than the upper boundary // which might be infinity // visualize the boundary CGAL_triangulation_assertion(((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR) || (classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == SINGULAR))); Alpha_shape_edges_list.push_back(Edge((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)); } } } } use_edge_cache = true; } //------------------------------------------------------------------------- template < class Dt > typename Alpha_shape_2<Dt>::Classification_type Alpha_shape_2<Dt>::classify(const Face_handle& f, int i, const Coord_type& alpha) const { // Classifies the edge `e' of the underlying Delaunay // triangulation with respect to `A'. // the version that uses a simplified version without crosslinks // is much slower if (is_infinite(f, i)) return EXTERIOR; // we store only finite edges in _edge_interval_map Interval3 interval = find_interval(const_Edge(f, i)); // (*(_edge_interval_map.find(const_Edge(f, i)))).second; if (alpha < interval.second) { if (get_mode() == REGULARIZED || interval.first == UNDEFINED || alpha < interval.first) return EXTERIOR; else // alpha >= interval.first return SINGULAR; } else { // alpha >= interval.second if (interval.third == Infinity || alpha < interval.third) return REGULAR; else // alpha >= interval.third return INTERIOR; } } //------------------------------------------------------------------------- template < class Dt > typename Alpha_shape_2<Dt>::Classification_type Alpha_shape_2<Dt>::classify(const Vertex_handle& v, const Coord_type& alpha) const { // Classifies the vertex `v' of the underlying Delaunay // triangulation with respect to `A'. Interval2 interval = v->get_range(); if (alpha < interval.first) { if (get_mode() == REGULARIZED) return EXTERIOR; else // general => vertices are never exterior return SINGULAR; } else { // alpha >= interval.first if (interval.second == Infinity || alpha < interval.second) return REGULAR; else // alpha >= interval.second return INTERIOR; } } //------------------------------------------------------------------------- template < class Dt > typename Alpha_shape_2<Dt>::size_type Alpha_shape_2<Dt>::number_of_solid_components(const Coord_type& alpha) const { // Determine the number of connected solid components typedef typename Marked_face_set::Data Data; Marked_face_set marked_face_set(false); Finite_faces_iterator face_it; size_type nb_solid_components = 0; if (number_of_vertices()==0) return 0; // only finite faces for( face_it = faces_begin(); face_it != faces_end(); ++face_it) { Face_handle pFace = face_it; CGAL_triangulation_postcondition( pFace != NULL); if (classify(pFace, alpha) == INTERIOR){ Data& data = marked_face_set[pFace]; if(data == false) { // we traverse only interior faces traverse(pFace, marked_face_set, alpha); nb_solid_components++; } } } return nb_solid_components; } //------------------------------------------------------------------------- template < class Dt > void Alpha_shape_2<Dt>::traverse(const Face_handle& pFace, Marked_face_set& marked_face_set, const Coord_type alpha) const { typedef typename Marked_face_set::Data Data; std::list<Face_handle> faces; faces.push_back(pFace); Face_handle pNeighbor, fh; while(! faces.empty()){ fh = faces.front(); faces.pop_front(); for (int i=0; i<3; i++) { pNeighbor = fh->neighbor(i); CGAL_triangulation_assertion(pNeighbor != NULL); if (classify(pNeighbor, alpha) == INTERIOR){ Data& data = marked_face_set[pNeighbor]; if(data == false){ data = true; faces.push_back(pNeighbor); } } } } } //------------------------------------------------------------------------- template < class Dt > typename Alpha_shape_2<Dt>::Alpha_iterator Alpha_shape_2<Dt>::find_optimal_alpha(size_type nb_components) { // find the minimum alpha that satisfies the properties // (1) nb_components solid components // (2) all data points on the boundary or in its interior Coord_type alpha = find_alpha_solid(); // from this alpha on the alpha_solid satisfies property (2) Alpha_iterator first = alpha_lower_bound(alpha); if (number_of_solid_components(alpha) == nb_components) { if ((first+1) < alpha_end()) return (first+1); else return first; } // do binary search on the alpha values // number_of_solid_components() is a monotone function // if we start with find_alpha_solid Alpha_iterator last = alpha_end(); Alpha_iterator middle; std::ptrdiff_t len = last - first - 1; std::ptrdiff_t half; while (len > 0) { half = len / 2; middle = first + half; #ifdef CGAL_DEBUG_ALPHA_SHAPE_2 std::cout << "first : " << *first << " last : " << *(first+len) << " mid : " << *middle << " nb comps : " << number_of_solid_components(*middle) << std::endl; #endif // CGAL_DEBUG_ALPHA_SHAPE_2 if (number_of_solid_components(*middle) > nb_components) { first = middle + 1; len = len - half - 1; } else { // number_of_solid_components(*middle) <= nb_components len = half; } } if ((first+1) < alpha_end()) return (first+1); else return first; } //------------------------------------------------------------------------- template < class Dt > typename Alpha_shape_2<Dt>::Coord_type Alpha_shape_2<Dt>::find_alpha_solid() const { // compute the minumum alpha such that all data points // are either on the boundary or in the interior // not necessarily connected // starting point for searching // takes O(#alpha_shape) time Coord_type alpha_solid = 0; Finite_vertices_iterator vertex_it; // only finite vertices for( vertex_it = finite_vertices_begin(); vertex_it != finite_vertices_end(); ++vertex_it) { Coord_type alpha_min_v = (--_interval_face_map.end())->first; Face_circulator face_circ = this->incident_faces(vertex_it); Face_circulator done = face_circ; do { Face_handle f = face_circ; if (! is_infinite(f)) alpha_min_v = CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION(find_interval(f), alpha_min_v); } while (++face_circ != done); alpha_solid = CGAL::max BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_min_v, alpha_solid); } return alpha_solid; } //------------------------------------------------------------------------- template < class Dt > std::ostream& Alpha_shape_2<Dt>::op_ostream(std::ostream& os) const { typedef typename Alpha_shape_2<Dt>::Interval_vertex_map Interval_vertex_map ; typename Interval_vertex_map::const_iterator vertex_alpha_it; const typename Alpha_shape_2<Dt>::Interval2* pInterval2; Unique_hash_map< Vertex_handle , size_type > V; size_type number_of_vertices = 0; typedef typename Alpha_shape_2<Dt>::Interval_edge_map Interval_edge_map; typename Interval_edge_map::const_iterator edge_alpha_it; const typename Alpha_shape_2<Dt>::Interval3* pInterval; if (get_mode() == Alpha_shape_2<Dt>::REGULARIZED) { typename Alpha_shape_2<Dt>::Vertex_handle v; for (vertex_alpha_it = _interval_vertex_map.begin(); vertex_alpha_it != _interval_vertex_map.end() && (*vertex_alpha_it).first.first <= get_alpha(); ++vertex_alpha_it) { pInterval2 = &(*vertex_alpha_it).first; #ifdef CGAL_DEBUG_ALPHA_SHAPE_2 typename Alpha_shape_2<Dt>::Coord_type alpha = get_alpha(); typename Alpha_shape_2<Dt>::Coord_type alpha_mid = pInterval2->first; typename Alpha_shape_2<Dt>::Coord_type alpha_max = pInterval2->second; #endif // CGAL_DEBUG_ALPHA_SHAPE_2 if((pInterval2->second > get_alpha() || pInterval2->second == Infinity)) { // alpha must be larger than the min boundary // and alpha is smaller than the upper boundary // which might be infinity // write the vertex v = (*vertex_alpha_it).second; CGAL_triangulation_assertion((classify(v) == Alpha_shape_2<Dt>::REGULAR)); // if we used Edelsbrunner and Muecke's definition // regular means incident to a higher-dimensional face // we would write too many vertices V[v] = number_of_vertices++; os << v->point() << std::endl; } } // the vertices are oriented counterclockwise typename Alpha_shape_2<Dt>::Face_handle f; int i; for (edge_alpha_it = _interval_edge_map.begin(); edge_alpha_it != _interval_edge_map.end() && (*edge_alpha_it).first.first <= get_alpha(); ++edge_alpha_it) { pInterval = &(*edge_alpha_it).first; CGAL_triangulation_assertion(pInterval->second != Infinity); // since this happens only for convex hull of dimension 1 // thus singular if(pInterval->second <= get_alpha() && (pInterval->third > get_alpha() || pInterval->third == Infinity)) { // alpha must be larger than the mid boundary // and alpha is smaller than the upper boundary // which might be infinity // visualize the boundary f = (*edge_alpha_it).second.first; i = (*edge_alpha_it).second.second; // assure that all vertices are in ccw order if (classify(f) == Alpha_shape_2<Dt>::EXTERIOR) { // take the reverse face typename Alpha_shape_2<Dt>::Face_handle pNeighbor = f->neighbor(i); i = pNeighbor->index(f); f = pNeighbor; } CGAL_triangulation_assertion((classify(f) == Alpha_shape_2<Dt>::INTERIOR)); CGAL_triangulation_assertion((classify(f, i) == Alpha_shape_2<Dt>::REGULAR)); os << V[f->vertex(f->ccw(i))] << ' ' << V[f->vertex(f->cw(i))] << std::endl; } } } else { // get_mode() == GENERAL ----------------------------------------- typename Alpha_shape_2<Dt>::Vertex_handle v; // write the regular vertices for (vertex_alpha_it = _interval_vertex_map.begin(); vertex_alpha_it != _interval_vertex_map.end() && (*vertex_alpha_it).first.first <= get_alpha(); ++vertex_alpha_it) { pInterval2 = &(*vertex_alpha_it).first; if((pInterval2->second > get_alpha() || pInterval2->second == Infinity)) { // alpha must be larger than the min boundary // and alpha is smaller than the upper boundary // which might be infinity // write the vertex v = (*vertex_alpha_it).second; CGAL_triangulation_assertion((classify(v) == Alpha_shape_2<Dt>::REGULAR)); V[v] = number_of_vertices++; os << v->point() << std::endl; } } // write the singular vertices for (; vertex_alpha_it != _interval_vertex_map.end(); ++vertex_alpha_it) { v = (*vertex_alpha_it).second; CGAL_triangulation_assertion((classify(v) == Alpha_shape_2<Dt>::SINGULAR)); V[v] = number_of_vertices++; os << v->point() << std::endl; } // the vertices are oriented counterclockwise typename Alpha_shape_2<Dt>::Face_handle f; int i; for (edge_alpha_it = _interval_edge_map.begin(); edge_alpha_it != _interval_edge_map.end() && (*edge_alpha_it).first.first <= get_alpha(); ++edge_alpha_it) { pInterval = &(*edge_alpha_it).first; #ifdef CGAL_DEBUG_ALPHA_SHAPE_2 typename Alpha_shape_2<Dt>::Coord_type alpha = get_alpha(); typename Alpha_shape_2<Dt>::Coord_type alpha_min = pInterval->first; typename Alpha_shape_2<Dt>::Coord_type alpha_mid = pInterval->second; typename Alpha_shape_2<Dt>::Coord_type alpha_max = pInterval->third; #endif // CGAL_DEBUG_ALPHA_SHAPE_2 if(pInterval->third > get_alpha() || pInterval->third == Infinity) { // if alpha is smaller than the upper boundary // which might be infinity // visualize the boundary f = (*edge_alpha_it).second.first; i = (*edge_alpha_it).second.second; // write the regular edges if (pInterval->second != Infinity && pInterval->second <= get_alpha()) { CGAL_triangulation_assertion((classify(f, i) == Alpha_shape_2<Dt>::REGULAR)); // assure that all vertices are in ccw order if (classify(f) == Alpha_shape_2<Dt>::EXTERIOR) { // take the reverse face typename Alpha_shape_2<Dt>::Face_handle pNeighbor = f->neighbor(i); i = pNeighbor->index(f); f = pNeighbor; } CGAL_triangulation_assertion((classify(f) == Alpha_shape_2<Dt>::INTERIOR)); os << V[f->vertex(f->ccw(i))] << ' ' << V[f->vertex(f->cw(i))] << std::endl; } else { // pInterval->second == Infinity || // pInterval->second >= get_alpha()) // pInterval->second == Infinity happens only for convex hull // of dimension 1 thus singular // write the singular edges if (pInterval->first != UNDEFINED) { CGAL_triangulation_assertion((classify(f, i) == Alpha_shape_2<Dt>::SINGULAR)); os << V[f->vertex(f->ccw(i))] << ' ' << V[f->vertex(f->cw(i))] << std::endl; } } } } } return os; } //------------------------------------------------------------------- template < class Dt > std::ostream& operator<<(std::ostream& os, const Alpha_shape_2<Dt>& A) { return A.op_ostream(os); } //------------------------------------------------------------------- template < class Dt > std::list<typename Alpha_shape_2<Dt>::Point> Alpha_shape_2<Dt>::Output () { typename Interval_edge_map::const_iterator edge_alpha_it; const Interval3* pInterval; std::list<Point> L; if (get_mode() == REGULARIZED) { // it is much faster looking at the sorted intervals // than looking at all sorted faces // alpha must be larger than the mid boundary // and alpha is smaller than the upper boundary for (edge_alpha_it = _interval_edge_map.begin(); edge_alpha_it != _interval_edge_map.end() && (*edge_alpha_it).first.first <= get_alpha(); ++edge_alpha_it) { pInterval = &(*edge_alpha_it).first; if (pInterval->second != Infinity) { // since this happens only for convex hull of dimension 1 // thus singular if(pInterval->second <= get_alpha() && (pInterval->third > get_alpha() || pInterval->third == Infinity)) { // alpha must be larger than the mid boundary // and alpha is smaller than the upper boundary // which might be infinity // visualize the boundary CGAL_triangulation_assertion((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR)); // if we used Edelsbrunner and Muecke's definition // regular means incident to a higher-dimensional face // thus we would write to many vertices L.push_back((segment((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)) .source()); L.push_back((segment((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)) .target()); } } } } else { // get_mode() == GENERAL // draw the edges for (edge_alpha_it = _interval_edge_map.begin(); edge_alpha_it != _interval_edge_map.end() && (*edge_alpha_it).first.first <= get_alpha(); ++edge_alpha_it) { pInterval = &(*edge_alpha_it).first; if (pInterval->first == UNDEFINED) { CGAL_triangulation_assertion(pInterval->second != Infinity); // since this happens only for convex hull of dimension 1 // thus singular if(pInterval->second <= get_alpha() && (pInterval->third > get_alpha() || pInterval->third == Infinity)) { // alpha must be larger than the mid boundary // and alpha is smaller than the upper boundary // which might be infinity // visualize the boundary CGAL_triangulation_assertion((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR)); L.push_back((segment((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)) .source()); L.push_back((segment((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)) .target()); } } else { if(pInterval->third > get_alpha() || pInterval->third == Infinity) { // if alpha is smaller than the upper boundary // which might be infinity // visualize the boundary CGAL_triangulation_assertion(((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR) || (classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == SINGULAR))); L.push_back((segment((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)) .source()); L.push_back((segment((*edge_alpha_it).second.first, (*edge_alpha_it).second.second)) .target()); } } } } return L; } template < class Dt > void Alpha_shape_2<Dt>::print_edge_map() { for (typename Interval_edge_map::iterator iemapit= _interval_edge_map.begin(); iemapit != _interval_edge_map.end(); ++iemapit) { Interval3 interval = (*iemapit).first; Edge edge = (*iemapit).second; Point p1 = edge.first->vertex(cw(edge.second))->point(); Point p2 = edge.first->vertex(ccw(edge.second))->point(); std::cout << "[ (" << p1 << ") - (" << p2 << ") ] : " << interval.first << " " << interval.second << " " << interval.third << std::endl; } } } //namespace CGAL #endif //CGAL_ALPHA_SHAPE_2_H
- Re: [cgal-discuss] Alpha_shape_2 with info, (continued)
- Re: [cgal-discuss] Alpha_shape_2 with info, Asher Kamiraze, 05/19/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Mariette Yvinec, 05/19/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Sebastien Loriot (GeometryFactory), 05/19/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Asher Kamiraze, 05/27/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Sebastien Loriot (GeometryFactory), 05/27/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Andreas Fabri, 05/27/2011
