cgal-discuss - Re: [cgal-discuss] Alpha_shape_2 with info
  • To:
  • Subject: Re: [cgal-discuss] Alpha_shape_2 with info
  • Date: Thu, 19 May 2011 16:40:08 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=b1uIFMz0KgSao52MOO9jrJNjlWCvbS8Jwpuk9nNADe7gh6EuzNwbJ8J61lCdmzV3Ec vHLHNhoYejqTV8arA5qJAHtkwcpFsLIYbuR4asraQ729tK/fbcsl2eeksvbhw//pBXGh e+N0of8iRHiXnwfWaZMy1VlmFJ/uPElh8Qs0U=
Thank you Sebastien
I finally did that and it seems to work:
  Alpha_shape_2(Dt& dt, NT alpha = 0, Mode m = REGULARIZED)
      :_alpha(alpha), _mode(m),
      use_vertex_cache(false), use_edge_cache(false)
      Dt::swap(dt);
      if (dimension() == 2)
          // Compute the associated _interval_face_map
          initialize_interval_face_map();
          // Compute the associated _interval_edge_map
          initialize_interval_edge_map();
          // Compute the associated _interval_vertex_map
          initialize_interval_vertex_map();
          // merge the two maps
          initialize_alpha_spectrum();
Thank you for your help.
Regards,
Asher
2011/5/19 Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com>
Asher Kamiraze wrote:
OK. May this simple hack inspired from the 3D version will work?
That's what I did too.
S.
   :_alpha(alpha), _mode(m),     use_vertex_cache(false), use_facet_cache(false)
     Dt::swap(dt);
     if (dimension() == 2) initialize_alpha();
Regards,
Asher
2011/5/19 Mariette Yvinec < <mailto:>>
   I see ...
   In 3D you may construct  the Alpha_shape from the Triangulation
   so that you can enter your vertices wih their info
   in the triangulation and then build the Alpha_shape from the
   triangulation.
   In 2D, such a constructor does not seem to exist.
   Obviously, we should add it.
   Regards,
   Mariette
   Le 19/05/11 15:52, Asher Kamiraze a écrit :
   Hi,
   <mailto:>>
       push_back should be private too.
   Yes, that's what I thought.
       If you use push_back,
        the triangulation will be updated but not the alpha_shapes...
       I don't see any problem in what you propose.
   Since I can use neither push_back nor insert, how can I attach
   info to a vertex?
   If it is a triangulation, I add a point and get the returned
   vertex, then attach the info on it. With alpha shapes, I have to
   give as input a range of points, and do not know how to attach
   info of the resulting vertices.
   Regards,
   Asher
       Le 19/05/11 12:46, Asher Kamiraze a écrit :
           Hi all,
           Is there a way to build an alpha_shape_2 with info?
           Something similar to a triangulation with info.
           I have also noticed that insert() is private in
           alpha_shape_2, but, push_back is not. Isn't it a problem?
           Here is what I am trying to do:
              typedef
           CGAL::Exact_predicates_exact_constructions_kernel                                  K;
              struct vertex_info { Point point3d; };
              struct face_info {};
              typedef
           CGAL::Triangulation_vertex_base_with_info_2<vertex_info,K>
                        Vb_2;
              typedef
           CGAL::Constrained_triangulation_face_base_with_info_2<face_info,K>
                Fb_2;
              typedef CGAL::Alpha_shape_vertex_base_2<K, Vb_2> Vb;
              typedef CGAL::Alpha_shape_face_base_2<K, Fb_2>  Fb;
              typedef CGAL::Triangulation_data_structure_2<Vb,Fb>                                    TDS_2;
              typedef CGAL::Delaunay_triangulation_2<K  , TDS_2>                                         DT_2;
              typedef CGAL::Alpha_shape_2<DT_2> Alpha_shape_2;
                      Alpha_shape_2 alpha_shape(0.5);
                      // How to insert points in alpha_shape with
           attached info?
           Hope you could help
           Best regards
           Asher
       --         Mariette Yvinec
       Geometrica project team
       INRIA  Sophia-Antipolis
       --         You are currently subscribed to cgal-discuss.
   --     Mariette Yvinec
