cgal-discuss - Re: [cgal-discuss] Alpha_shape_2 with info
  • To:
  • Subject: Re: [cgal-discuss] Alpha_shape_2 with info
  • Date: Thu, 19 May 2011 16:44:49 +0200
Sorry this is this that I posted in my first
mail + setting Infinity to -1 and UNDEFINED to -2
(that you are missing here).
S.
Asher Kamiraze wrote:
Thank you Sebastien
I finally did that and it seems to work:
Alpha_shape_2(Dt& dt, NT alpha = 0, Mode m = REGULARIZED)
:_alpha(alpha), _mode(m), use_vertex_cache(false), use_edge_cache(false)
Dt::swap(dt);
if (dimension() == 2)
// Compute the associated _interval_face_map
initialize_interval_face_map();
// Compute the associated _interval_edge_map
initialize_interval_edge_map();
// Compute the associated _interval_vertex_map
initialize_interval_vertex_map();
// merge the two maps
initialize_alpha_spectrum();
Thank you for your help.
Regards,
Asher
2011/5/19 Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>>
OK. May this simple hack inspired from the 3D version will work?
That's what I did too.
S.
use_facet_cache(false)
Dt::swap(dt);
if (dimension() == 2) initialize_alpha();
Regards,
Asher
2011/5/19 Mariette Yvinec
<mailto:>
<mailto:
<mailto:>>>
I see ...
In 3D you may construct the Alpha_shape from the Triangulation
so that you can enter your vertices wih their info
in the triangulation and then build the Alpha_shape from the
triangulation.
In 2D, such a constructor does not seem to exist.
Obviously, we should add it.
Regards,
Mariette
Le 19/05/11 15:52, Asher Kamiraze a écrit :
Hi,
<mailto:>
<mailto:
<mailto:>>>
push_back should be private too.
Yes, that's what I thought.
If you use push_back,
the triangulation will be updated but not the
alpha_shapes...
I don't see any problem in what you propose.
Since I can use neither push_back nor insert, how can I
attach
info to a vertex?
If it is a triangulation, I add a point and get the returned
vertex, then attach the info on it. With alpha shapes, I
have to
give as input a range of points, and do not know how to
attach
info of the resulting vertices.
Regards,
Asher
Le 19/05/11 12:46, Asher Kamiraze a écrit :
Hi all,
Is there a way to build an alpha_shape_2 with info?
Something similar to a triangulation with info.
I have also noticed that insert() is private in
alpha_shape_2, but, push_back is not. Isn't it a
problem?
Here is what I am trying to do:
typedef
CGAL::Exact_predicates_exact_constructions_kernel
K;
struct vertex_info { Point point3d; };
struct face_info {};
typedef
CGAL::Triangulation_vertex_base_with_info_2<vertex_info,K>
Vb_2;
typedef
CGAL::Constrained_triangulation_face_base_with_info_2<face_info,K>
Fb_2;
typedef CGAL::Alpha_shape_vertex_base_2<K,
Vb_2> Vb;
typedef CGAL::Alpha_shape_face_base_2<K, Fb_2>
Fb;
typedef
CGAL::Triangulation_data_structure_2<Vb,Fb> TDS_2;
typedef CGAL::Delaunay_triangulation_2<K ,
TDS_2> DT_2;
typedef CGAL::Alpha_shape_2<DT_2> Alpha_shape_2;
Alpha_shape_2 alpha_shape(0.5);
// How to insert points in alpha_shape
with
attached info?
Hope you could help
Best regards
Asher
-- Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
-- You are currently subscribed to cgal-discuss.
-- Mariette Yvinec
