cgal-discuss - Re: [cgal-discuss] Alpha_shape_2 with info
  • To:
  • Subject: Re: [cgal-discuss] Alpha_shape_2 with info
  • Date: Fri, 27 May 2011 14:40:31 +0200
Asher Kamiraze wrote:
Mariette, Sebastien,
Thank you, it works well. I am now facing another problem. I would like to iterate over the *ordered *boundary vertices of the computer alpha-shape, but I cannot figure how to do it.
You recently answered a similar question, but I do not understand your solution:
"Iterate over REGULAR edges and build the graph of vertices.
From this you should be able to get the contour. You might also
might consider SINGULAR edges to get antennas".
How do you build the graph of vertices?
You have a set of vertices and a set of edges.
Use a std::map<Vertex_handle,std::vector<Vertex_handle> > or whatever
classical solution to build the graph.
>What if I want to build a 3D polyline with the boundary vertices?
A polyline is a 2D graph so I don't see the problem.
S.
Hope you could help.
Regards,
Asher
2011/5/19 Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>>
Sorry this is this that I posted in my first
mail + setting Infinity to -1 and UNDEFINED to -2
(that you are missing here).
S.
Thank you Sebastien
I finally did that and it seems to work:
Alpha_shape_2(Dt& dt, NT alpha = 0, Mode m = REGULARIZED)
:_alpha(alpha), _mode(m), use_vertex_cache(false),
use_edge_cache(false)
Dt::swap(dt);
if (dimension() == 2)
// Compute the associated _interval_face_map
initialize_interval_face_map();
// Compute the associated _interval_edge_map
initialize_interval_edge_map();
// Compute the associated _interval_vertex_map
initialize_interval_vertex_map();
// merge the two maps
initialize_alpha_spectrum();
Thank you for your help.
Regards,
Asher
<http://sloriot.ml> <http://sloriot.ml>@gmail.com
<http://gmail.com> <http://gmail.com>>
OK. May this simple hack inspired from the 3D version
will work?
That's what I did too.
S.
use_facet_cache(false)
Dt::swap(dt);
if (dimension() == 2) initialize_alpha();
Regards,
Asher
2011/5/19 Mariette Yvinec
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>
I see ...
In 3D you may construct the Alpha_shape from the
Triangulation
so that you can enter your vertices wih their info
in the triangulation and then build the Alpha_shape
from the
triangulation.
In 2D, such a constructor does not seem to exist.
Obviously, we should add it.
Regards,
Mariette
Le 19/05/11 15:52, Asher Kamiraze a écrit :
Hi,
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>
push_back should be private too.
Yes, that's what I thought.
If you use push_back,
the triangulation will be updated but not the
alpha_shapes...
I don't see any problem in what you propose.
Since I can use neither push_back nor insert, how
can I
attach
info to a vertex?
If it is a triangulation, I add a point and get
the returned
vertex, then attach the info on it. With alpha
shapes, I
have to
give as input a range of points, and do not know
how to
attach
info of the resulting vertices.
Regards,
Asher
Le 19/05/11 12:46, Asher Kamiraze a écrit :
Hi all,
Is there a way to build an alpha_shape_2
with info?
Something similar to a triangulation with
info.
I have also noticed that insert() is
private in
alpha_shape_2, but, push_back is not.
Isn't it a
problem?
Here is what I am trying to do:
typedef
CGAL::Exact_predicates_exact_constructions_kernel
K;
struct vertex_info { Point point3d; };
struct face_info {};
typedef
CGAL::Triangulation_vertex_base_with_info_2<vertex_info,K>
Vb_2;
typedef
CGAL::Constrained_triangulation_face_base_with_info_2<face_info,K>
Fb_2;
typedef CGAL::Alpha_shape_vertex_base_2<K,
Vb_2> Vb;
typedef
CGAL::Alpha_shape_face_base_2<K, Fb_2>
Fb;
typedef
CGAL::Triangulation_data_structure_2<Vb,Fb> TDS_2;
typedef CGAL::Delaunay_triangulation_2<K ,
TDS_2> DT_2;
typedef CGAL::Alpha_shape_2<DT_2>
Alpha_shape_2;
Alpha_shape_2 alpha_shape(0.5);
// How to insert points in
alpha_shape
with
attached info?
Hope you could help
Best regards
Asher
-- Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
-- You are currently subscribed to
cgal-discuss.
-- Mariette Yvinec
-- You are currently subscribed to cgal-discuss.
