cgal-discuss - Re: [cgal-discuss] Alpha_shape_2 with info
  • To:
  • Subject: Re: [cgal-discuss] Alpha_shape_2 with info
  • Date: Thu, 19 May 2011 16:33:44 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=arkL59NCd4n4YW/GJznxKuVtAQT9QB21JuktzvFO3kBFkWJwXR6SmFKElkIgMXdxci 4XcJ+SMj8LZPeZbCRccJTNIHsTTh3DwQA3HN91tRB6QdicGYEvqXWWJS6+lD4BEFPip9 +wS6KyoSPK9HE+CfVy+f07nAXfdfLmmmPVjzk=
OK. May this simple hack inspired from the 3D version will work?
  Alpha_shape_2(Dt& dt, NT alpha = 0, Mode m = REGULARIZED)
    :_alpha(alpha), _mode(m),
    use_vertex_cache(false), use_facet_cache(false)
      Dt::swap(dt);
      if (dimension() == 2) initialize_alpha();
Regards,
Asher
2011/5/19 Mariette Yvinec <>
I see ...
In 3D you may construct  the Alpha_shape from the Triangulation
so that you can enter your vertices wih their info
in the triangulation and then build the Alpha_shape from the triangulation.
In 2D, such a constructor does not seem to exist.
Obviously, we should add it.
Regards,
Mariette
Le 19/05/11 15:52, Asher Kamiraze a écrit :
Hi,
push_back should be private too.
Yes, that's what I thought.
If you use push_back,
 the triangulation will be updated but not the alpha_shapes...
I don't see any problem in what you propose.
Since I can use neither push_back nor insert, how can I attach info to a vertex?
If it is a triangulation, I add a point and get the returned vertex, then attach the info on it. With alpha shapes, I have to give as input a range of points, and do not know how to attach info of the resulting vertices.
Regards,
Asher
Le 19/05/11 12:46, Asher Kamiraze a écrit :
Hi all,
Is there a way to build an alpha_shape_2 with info? Something similar to a triangulation with info.
I have also noticed that insert() is private in alpha_shape_2, but, push_back is not. Isn't it a problem?
Here is what I am trying to do:
   typedef CGAL::Exact_predicates_exact_constructions_kernel                       K;
   struct vertex_info { Point point3d; };
   struct face_info {};
   typedef CGAL::Triangulation_vertex_base_with_info_2<vertex_info,K>              Vb_2;
   typedef CGAL::Constrained_triangulation_face_base_with_info_2<face_info,K>      Fb_2;
   typedef CGAL::Alpha_shape_vertex_base_2<K, Vb_2> Vb;
   typedef CGAL::Alpha_shape_face_base_2<K, Fb_2>  Fb;
   typedef CGAL::Triangulation_data_structure_2<Vb,Fb>                         TDS_2;
   typedef CGAL::Delaunay_triangulation_2<K  , TDS_2>                              DT_2;
   typedef CGAL::Alpha_shape_2<DT_2> Alpha_shape_2;
           Alpha_shape_2 alpha_shape(0.5);
           // How to insert points in alpha_shape with attached info?
Hope you could help
Best regards
Asher
Mariette Yvinec
Geometrica project team
INRIA  Sophia-Antipolis
Mariette Yvinec
