cgal-discuss - Re: [cgal-discuss] Voronoi diagrams
  • To:
  • Subject: Re: [cgal-discuss] Voronoi diagrams
  • Date: Fri, 20 May 2011 11:58:14 +0200
On vendredi 20 mai 2011 11:43:48 Brian Sanjeewa Rupasinghe wrote:
> CMake Error: The following variables are used in this project, but they are
> set to NOTFOUND. Please set them or make sure they are set and tested
> correctly in the CMake files: Boost_INCLUDE_DIR (ADVANCED)
This error is rather explicit actually. You need to have Boost installed, and
Boost_INCLUDE_DIR must be filled with something like C:/CGAL/boost_1_46 (ie
the directory where you can find the ./Boost subdirecty that contains Boost
headers).
You will also have to fill CMake variables about Boost precompiled libraries.
As said in the installation manual of CGAL, the easiest way is to remove all
Boost_* variables from the CMake cache¹, and add² a variable BOOST_ROOT, of
type "Path", that points to C:/CGAL/boost_1_46 (or the location where you
installed Boost header and precompiled libraries), and reclick on configure.
With BOOST_ROOT, CMake will be able to find the headers and the libraries
automatically.
¹) in the CMake GUI, selected them, and click on the "Remove entry" button.
²) With the button "Add entry" of course.
Laurent Rineau, PhD
