- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Fri, 20 May 2011 10:52:26 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=FlZ/WvMGQGMnGrX+cjv75FtTtyXUEP1+urnLpWR48gKFrl7bbT9n5i3LiXZYssxY0e WdO1OkX+zqKyNp1xr2nRgNZrl+VzUXOfFtOzgcNt4a3JkBMBrbMYZ09iqiydKgIZ6LAW YAn+LypDoOh48JICJx+7F8V0KGgJ7VgXryh2M=
Yes, I installed Boost. Please give me steps to adjust the path. Should it be adjusted in
CMAKE or in windows system environment?
Brian.
On Fri, May 20, 2011 at 10:46 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Did you installed boost?
If yes you need to adjust the path in Boost_INCLUDE_DIR in the GUI.
S.
Brian Sanjeewa Rupasinghe wrote:
This is the kinds of errors at the end:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
Boost_INCLUDE_DIR (ADVANCED)
used as include directory in directory C:/Program Files/CGAL-3.7/src/CGAL
used as include directory in directory C:/Program Files/CGAL-3.7/src/CGALCore
used as include directory in directory C:/Program Files/CGAL-3.7/src/CGALimageIO
used as include directory in directory C:/Program Files/CGAL-3.7/src/CGALQt
used as include directory in directory C:/Program Files/CGAL-3.7/src/CGALQt4
used as include directory in directory C:/Program Files/CGAL-3.7/examples/AABB_tree
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Algebraic_foundations
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Algebraic_kernel_d
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Alpha_shapes_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Alpha_shapes_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Apollonius_graph_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Approximate_min_ellipsoid_d
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Arrangement_on_surface_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/BGL_arrangement_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/BGL_polyhedron_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/BGL_triangulation_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Boolean_set_operations_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Box_intersection_d
used as include directory in directory C:/Program Files/CGAL-3.7/examples/CGAL_ipelets
used as include directory in directory C:/Program Files/CGAL-3.7/examples/CGALimageIO
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Circular_kernel_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Circular_kernel_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Circulator
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Convex_decomposition_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Convex_hull_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Convex_hull_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Core
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Developers_manual
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Envelope_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Envelope_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Filtered_kernel
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Generator
used as include directory in directory C:/Program Files/CGAL-3.7/examples/HalfedgeDS
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Interpolation
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Interval_skip_list
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Jet_fitting_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Kernel_23
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Kinetic_data_structures
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Kinetic_framework
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Largest_empty_rect_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Matrix_search
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Mesh_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Mesh_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Min_annulus_d
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Min_circle_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Min_ellipse_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Min_quadrilateral_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Min_sphere_d
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Min_sphere_of_spheres_d
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Minkowski_sum_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Minkowski_sum_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Modular_arithmetic
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Nef_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Nef_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Nef_S2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Partition_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Periodic_3_triangulation_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Point_set_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Point_set_processing_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Polygon
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Polyhedron
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Polyhedron_IO
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Polynomial
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Polynomial_kernel
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Polytope_distance_d
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Principal_component_analysis
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Profiling_tools
used as include directory in directory C:/Program Files/CGAL-3.7/examples/QP_solver
used as include directory in directory C:/Program Files/CGAL-3.7/examples/RangeSegmentTrees
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Ridges_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/STL_Extension
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Segment_Delaunay_graph_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Skin_surface_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Snap_rounding_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Spatial_searching
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Spatial_sorting
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Straight_skeleton_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Stream_lines_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Subdivision_method_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Surface_mesh_parameterization
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Surface_mesh_simplification
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Surface_mesher
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Surface_reconstruction_points_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Triangulation_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Triangulation_3
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Voronoi_diagram_2
used as include directory in directory C:/Program Files/CGAL-3.7/examples/Width_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/AABB_tree
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Alpha_shapes_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Alpha_shapes_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Apollonius_graph_2/Qt3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Arrangement_on_surface_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Boolean_set_operations_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Bounding_volumes
used as include directory in directory C:/Program Files/CGAL-3.7/demo/CGAL_ipelets
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Circular_kernel_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Circular_kernel_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Convex_decomposition_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Convex_hull_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Convex_hull_d
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Envelope_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Generator
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Geomview
used as include directory in directory C:/Program Files/CGAL-3.7/demo/GraphicsView
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Interpolation
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Kinetic_data_structures
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Largest_empty_rect_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Matrix_search
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Mesh_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Mesh_2/Qt3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Mesh_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Nef_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Nef_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Nef_S2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Periodic_3_triangulation_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Periodic_Lloyd_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Polygon
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Polyhedron
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Polyhedron_IO
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Principal_component_analysis
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Robustness
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Segment_Delaunay_graph_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Snap_rounding_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Spatial_searching
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Straight_skeleton_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Stream_lines_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Surface_mesher
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Surface_reconstruction_points_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Triangulation_2
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Triangulation_3
used as include directory in directory C:/Program Files/CGAL-3.7/demo/Voronoi_diagram_2
Configuring incomplete, errors occurred!
On Fri, May 20, 2011 at 10:35 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
what are the errors you get in the text console of cmake?
Did you read them?
S.
Hi,
I tried with CGAL 3.8 too. But same eproblem occured. If you have
succeeded, could you please let me know the procedure.
Thanks.
Brian.
On Fri, May 20, 2011 at 10:14 AM, Andreas Fabri
<mailto:>
<mailto:
<mailto:>>> wrote:
Hello,
Your screenshot shows that it is CGAL-3.7
so this is inconsistent with
> I downlaoded both CGAL-3.8 Setup.exe
andreas
On 20/05/2011 11:09, Brian Sanjeewa Rupasinghe wrote:
Hi,
I installed CGAL and CMAKE with other libraries of Boost & QT
according
to the
instructions given in the website below. I have Visual
C++ 2008
Professional in
my computer on Windows 7. After configuring CMAKE to build
libraries, it
gave
an error. Please see the attachment. Could you please
help me to
solve this.
Actually my requirement is to use the libraries of
Traingulation and
Voronoi to
create my own clustering of point features. I need to
implement in
Visual C++ 2008.
So, please help me.
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
Brian.
On Wed, May 18, 2011 at 5:45 PM, Sebastien Loriot
(GeometryFactory)
<sloriot.ml <http://sloriot.ml> <http://sloriot.ml>
Dear Sir
Thanks, I found it. My next question is about the CGAL
configuration in CMAKE.
Could you pleas help?
I have visual c++ 2010 in my machine on windows 7.
I downlaoded both CGAL-3.8 Setup.exe and CMAKE-3.8
setup.exe. I installed both in my machine.
According to
the installation guide, I need to configure CGAL using
CMAKE configure button. However, in CMAKE GUI,
there are two buttons to browse 'source' and browse
Using Google I found that in 'source' you should
indicate the
path
containing the CMakeLists.txt (the root of CGAL)
and in 'build' the path where the lib will be
compiled. It can be
either the root of CGAL if you want to do an in-source
build
or whatever
directory you want (out-source build). The second
approach is
better if
you want ot use several version of the lib.
S.
'build'. What folders should i select over there?
In the
configuration, i chose generator as visual studio 10.
Brian.
On Wed, May 18, 2011 at 4:08 PM, Laurent Rineau
(GeometryFactory)
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>
<mailto:
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>> wrote:
On mercredi 18 mai 2011 16:53:21 Brian Sanjeewa
Rupasinghe
wrote:
> Hi,
> I cannot access www.cgal.org/demo
<http://www.cgal.org/demo>
<http://www.cgal.org/demo> <http://www.cgal.org/demo>
<http://www.cgal.org/demo>. Why?
That is one purpose. You do not need to have
access
to the
listing
of of the
content of that directory.
Links to precompiled demos are in the right bar of
this page:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/packages.html
The direct link to needed DLLs is:
http://www.cgal.org/demo/3.8/CGAL-demoDLLs.zip
Laurent Rineau, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
Release Manager of the CGAL Project
-- Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
-- You are currently subscribed to cgal-discuss.
--You are currently subscribed to cgal-discuss.
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/20/2011
