- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Fri, 20 May 2011 11:21:09 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=x6+yWdV+t9BwJsdJ6xeim/iQ5F8vdH2LQ6mj12dr+OGrd9lu7kr1CRUQn/ErpOtt9E ZFpui7hpLAokO0r8JQC4ENftgAj6+rzbPZ1VGFvbxV3qRAgBJU0LoGp9FF+zmOOPvQVR 5T6WQ8jZbdKTc72TnV71T12xIhHL+qnWVEUEQ=
Hi,
In the add entry, i find four things to input; name, type, value and description.
Please help to input values in this. I think for type PATH should be selected
and is it ok given there: c:/program files/boost/boost_1_46_1/boost
On Fri, May 20, 2011 at 10:56 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Brian Sanjeewa Rupasinghe wrote:cmake.
Yes, I installed Boost. Please give me steps to adjust the path. Should it be adjusted in
CMAKE or in windows system environment?
S.
Brian.
On Fri, May 20, 2011 at 10:46 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
Did you installed boost?
If yes you need to adjust the path in Boost_INCLUDE_DIR in the GUI.
S.
This is the kinds of errors at the end:
CMake Error: The following variables are used in this project,
but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly
in the CMake files:
Boost_INCLUDE_DIR (ADVANCED)
used as include directory in directory C:/Program
Files/CGAL-3.7/src/CGAL
Files/CGAL-3.7/src/CGALCore
Files/CGAL-3.7/src/CGALimageIO
Files/CGAL-3.7/src/CGALQt
Files/CGAL-3.7/src/CGALQt4
Files/CGAL-3.7/examples/AABB_tree
Files/CGAL-3.7/examples/Algebraic_foundations
Files/CGAL-3.7/examples/Algebraic_kernel_d
Files/CGAL-3.7/examples/Alpha_shapes_2
Files/CGAL-3.7/examples/Alpha_shapes_3
Files/CGAL-3.7/examples/Apollonius_graph_2
Files/CGAL-3.7/examples/Approximate_min_ellipsoid_d
Files/CGAL-3.7/examples/Arrangement_on_surface_2
Files/CGAL-3.7/examples/BGL_arrangement_2
Files/CGAL-3.7/examples/BGL_polyhedron_3
Files/CGAL-3.7/examples/BGL_triangulation_2
Files/CGAL-3.7/examples/Boolean_set_operations_2
Files/CGAL-3.7/examples/Box_intersection_d
Files/CGAL-3.7/examples/CGAL_ipelets
Files/CGAL-3.7/examples/CGALimageIO
Files/CGAL-3.7/examples/Circular_kernel_2
Files/CGAL-3.7/examples/Circular_kernel_3
Files/CGAL-3.7/examples/Circulator
Files/CGAL-3.7/examples/Convex_decomposition_3
Files/CGAL-3.7/examples/Convex_hull_2
Files/CGAL-3.7/examples/Convex_hull_3
Files/CGAL-3.7/examples/Core
Files/CGAL-3.7/examples/Developers_manual
Files/CGAL-3.7/examples/Envelope_2
Files/CGAL-3.7/examples/Envelope_3
Files/CGAL-3.7/examples/Filtered_kernel
Files/CGAL-3.7/examples/Generator
Files/CGAL-3.7/examples/HalfedgeDS
Files/CGAL-3.7/examples/Interpolation
Files/CGAL-3.7/examples/Interval_skip_list
Files/CGAL-3.7/examples/Jet_fitting_3
Files/CGAL-3.7/examples/Kernel_23
Files/CGAL-3.7/examples/Kinetic_data_structures
Files/CGAL-3.7/examples/Kinetic_framework
Files/CGAL-3.7/examples/Largest_empty_rect_2
Files/CGAL-3.7/examples/Matrix_search
Files/CGAL-3.7/examples/Mesh_2
Files/CGAL-3.7/examples/Mesh_3
Files/CGAL-3.7/examples/Min_annulus_d
Files/CGAL-3.7/examples/Min_circle_2
Files/CGAL-3.7/examples/Min_ellipse_2
Files/CGAL-3.7/examples/Min_quadrilateral_2
Files/CGAL-3.7/examples/Min_sphere_d
Files/CGAL-3.7/examples/Min_sphere_of_spheres_d
Files/CGAL-3.7/examples/Minkowski_sum_2
Files/CGAL-3.7/examples/Minkowski_sum_3
Files/CGAL-3.7/examples/Modular_arithmetic
Files/CGAL-3.7/examples/Nef_2
Files/CGAL-3.7/examples/Nef_3
Files/CGAL-3.7/examples/Nef_S2
Files/CGAL-3.7/examples/Partition_2
Files/CGAL-3.7/examples/Periodic_3_triangulation_3
Files/CGAL-3.7/examples/Point_set_2
Files/CGAL-3.7/examples/Point_set_processing_3
Files/CGAL-3.7/examples/Polygon
Files/CGAL-3.7/examples/Polyhedron
Files/CGAL-3.7/examples/Polyhedron_IO
Files/CGAL-3.7/examples/Polynomial
Files/CGAL-3.7/examples/Polynomial_kernel
Files/CGAL-3.7/examples/Polytope_distance_d
Files/CGAL-3.7/examples/Principal_component_analysis
Files/CGAL-3.7/examples/Profiling_tools
Files/CGAL-3.7/examples/QP_solver
Files/CGAL-3.7/examples/RangeSegmentTrees
Files/CGAL-3.7/examples/Ridges_3
Files/CGAL-3.7/examples/STL_Extension
Files/CGAL-3.7/examples/Segment_Delaunay_graph_2
Files/CGAL-3.7/examples/Skin_surface_3
Files/CGAL-3.7/examples/Snap_rounding_2
Files/CGAL-3.7/examples/Spatial_searching
Files/CGAL-3.7/examples/Spatial_sorting
Files/CGAL-3.7/examples/Straight_skeleton_2
Files/CGAL-3.7/examples/Stream_lines_2
Files/CGAL-3.7/examples/Subdivision_method_3
Files/CGAL-3.7/examples/Surface_mesh_parameterization
Files/CGAL-3.7/examples/Surface_mesh_simplification
Files/CGAL-3.7/examples/Surface_mesher
Files/CGAL-3.7/examples/Surface_reconstruction_points_3
Files/CGAL-3.7/examples/Triangulation_2
Files/CGAL-3.7/examples/Triangulation_3
Files/CGAL-3.7/examples/Voronoi_diagram_2
Files/CGAL-3.7/examples/Width_3
Files/CGAL-3.7/demo/AABB_tree
Files/CGAL-3.7/demo/Alpha_shapes_2
Files/CGAL-3.7/demo/Alpha_shapes_3
Files/CGAL-3.7/demo/Apollonius_graph_2/Qt3
Files/CGAL-3.7/demo/Arrangement_on_surface_2
Files/CGAL-3.7/demo/Boolean_set_operations_2
Files/CGAL-3.7/demo/Bounding_volumes
Files/CGAL-3.7/demo/CGAL_ipelets
Files/CGAL-3.7/demo/Circular_kernel_2
Files/CGAL-3.7/demo/Circular_kernel_3
Files/CGAL-3.7/demo/Convex_decomposition_3
Files/CGAL-3.7/demo/Convex_hull_3
Files/CGAL-3.7/demo/Convex_hull_d
Files/CGAL-3.7/demo/Envelope_3
Files/CGAL-3.7/demo/Generator
Files/CGAL-3.7/demo/Geomview
Files/CGAL-3.7/demo/GraphicsView
Files/CGAL-3.7/demo/Interpolation
Files/CGAL-3.7/demo/Kinetic_data_structures
Files/CGAL-3.7/demo/Largest_empty_rect_2
Files/CGAL-3.7/demo/Matrix_search
Files/CGAL-3.7/demo/Mesh_2
Files/CGAL-3.7/demo/Mesh_2/Qt3
Files/CGAL-3.7/demo/Mesh_3
Files/CGAL-3.7/demo/Nef_2
Files/CGAL-3.7/demo/Nef_3
Files/CGAL-3.7/demo/Nef_S2
Files/CGAL-3.7/demo/Periodic_3_triangulation_3
Files/CGAL-3.7/demo/Periodic_Lloyd_3
Files/CGAL-3.7/demo/Polygon
Files/CGAL-3.7/demo/Polyhedron
Files/CGAL-3.7/demo/Polyhedron_IO
Files/CGAL-3.7/demo/Principal_component_analysis
Files/CGAL-3.7/demo/Robustness
Files/CGAL-3.7/demo/Segment_Delaunay_graph_2
Files/CGAL-3.7/demo/Snap_rounding_2
Files/CGAL-3.7/demo/Spatial_searching
Files/CGAL-3.7/demo/Straight_skeleton_2
Files/CGAL-3.7/demo/Stream_lines_2
Files/CGAL-3.7/demo/Surface_mesher
Files/CGAL-3.7/demo/Surface_reconstruction_points_3
Files/CGAL-3.7/demo/Triangulation_2
Files/CGAL-3.7/demo/Triangulation_3
Files/CGAL-3.7/demo/Voronoi_diagram_2
Configuring incomplete, errors occurred!
On Fri, May 20, 2011 at 10:35 AM, Sebastien Loriot
(GeometryFactory) <sloriot.ml <http://sloriot.ml><http://gmail.com>> wrote:
what are the errors you get in the text console of cmake?
Did you read them?
S.
Hi,
I tried with CGAL 3.8 too. But same eproblem occured. If
you have
succeeded, could you please let me know the procedure.
Thanks.
Brian.
On Fri, May 20, 2011 at 10:14 AM, Andreas Fabri
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>> wrote:
Hello,
Your screenshot shows that it is CGAL-3.7
so this is inconsistent with
> I downlaoded both CGAL-3.8 Setup.exe
andreas
On 20/05/2011 11:09, Brian Sanjeewa Rupasinghe wrote:
Hi,
I installed CGAL and CMAKE with other libraries of
Boost & QT
according
to the
instructions given in the website below. I have Visual
C++ 2008
Professional in
my computer on Windows 7. After configuring CMAKE
to build
libraries, it
gave
an error. Please see the attachment. Could you please
help me to
solve this.
Actually my requirement is to use the libraries of
Traingulation and
Voronoi to
create my own clustering of point features. I need to
implement in
Visual C++ 2008.
So, please help me.
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
Brian.
On Wed, May 18, 2011 at 5:45 PM, Sebastien Loriot
(GeometryFactory)
<http://sloriot.ml> <http://sloriot.ml>
<http://gmail.com>
Dear Sir
Thanks, I found it. My next question is
about the CGAL
configuration in CMAKE.
Could you pleas help?
I have visual c++ 2010 in my machine on
windows 7.
I downlaoded both CGAL-3.8 Setup.exe and
CMAKE-3.8
setup.exe. I installed both in my machine.
According to
the installation guide, I need to configure
CGAL using
CMAKE configure button. However, in CMAKE GUI,
there are two buttons to browse 'source'
and browse
Using Google I found that in 'source' you should
indicate the
path
containing the CMakeLists.txt (the root of CGAL)
and in 'build' the path where the lib will be
compiled. It can be
either the root of CGAL if you want to do an
in-source
build
or whatever
directory you want (out-source build). The second
approach is
better if
you want ot use several version of the lib.
S.
'build'. What folders should i select over
there?
In the
configuration, i chose generator as visual
studio 10.
Brian.
On Wed, May 18, 2011 at 4:08 PM, Laurent Rineau
(GeometryFactory)
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>
<mailto:
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>
<mailto:
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>
<mailto:
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>>> wrote:
On mercredi 18 mai 2011 16:53:21 Brian
Sanjeewa
Rupasinghe
wrote:
> Hi,
> I cannot access www.cgal.org/demo
<http://www.cgal.org/demo>
<http://www.cgal.org/demo> <http://www.cgal.org/demo>
<http://www.cgal.org/demo>. Why?
That is one purpose. You do not need to
have
access
to the
listing
of of the
content of that directory.
Links to precompiled demos are in the
right bar of
this page:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/packages.html
The direct link to needed DLLs is:
http://www.cgal.org/demo/3.8/CGAL-demoDLLs.zip
Laurent Rineau, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
Release Manager of the CGAL Project
You are currently subscribed to
cgal-discuss.
To unsubscribe or access the archives,
go to
-- Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
-- You are currently subscribed to cgal-discuss.
--You are currently subscribed to cgal-discuss.
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/20/2011
