- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Fri, 20 May 2011 12:35:39 +0200
On vendredi 20 mai 2011 12:31:38 Brian Sanjeewa Rupasinghe wrote:
> Hi, thanks.
> I set BOOST_ROOT as you instructed. Now configuration did not give any
> error.
> But there are some files appearing in red on the GUI screen.
That is normal! Red variables are just variables whose value has changed
since
the previous configuration. And the "Generate" button should be availlable
now. If you click on it CMake will generate a VC solution and vcproj files.
Laurent Rineau, PhD
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
