- To:
- Subject: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN
- Date: Fri, 18 Nov 2011 14:49:59 +0100
Hi, I think only boost 1.48 has a /boost/type_traits/detail/has_binary_operator.hp file. Best regards.
Le 18/11/2011 10:36, Laurent Rineau (GeometryFactory) a écrit : Le vendredi 18 novembre 2011 00:47:13 Mark Brand a écrit :Hi, When building CGAL in mingw-cross-env, I noticed that the build failed if Qt happened to be present. This turned out to be caused by Qt's moc choking on a Boost header: <includedir>/boost/type_traits/detail/has_binary_operator.hp:50: Parse error at "BOOST_JOIN" I have seen this with Qt 4.8.0 and Qt 4.7.4.I Mark, Thanks for the report. I am surprised, because I use Qt-4.8 and boost-1.47, and the g++ compiler on Linux and I do not see that error. I would like to reproduce the bug before I apply you patch. - What version of Boost was involved? - And what version of mingw? - You talk about cross-compiling? What was the target-OS, and what was the host-OS? |
- [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Vivien Clauzon, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/18/2011
- Re: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/21/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/21/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, au9ustine, 11/20/2011
