- To:
- Subject: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN
- Date: Mon, 21 Nov 2011 17:29:24 +0100
Le vendredi 18 novembre 2011 00:47:13 Mark Brand a écrit :
> Hi,
> When building CGAL in mingw-cross-env, I noticed that the build failed
> if Qt happened to be present. This turned out to be caused by Qt's moc
> choking on a Boost header:
> <includedir>/boost/type_traits/detail/has_binary_operator.hp:50:
> Parse error at "BOOST_JOIN"
> I have seen this with Qt 4.8.0 and Qt 4.7.4.
I can confirm there is a bug with any recent version of Qt4 and Boost-1.48
(which is the last release of Boost libraries). It does not depend on the
system and compiler.
I will integrate your patch in the CGAL-3.9-branch, and probably release a
CGAL-3.9.1 soon.
Laurent Rineau, PhD
- [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Vivien Clauzon, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/18/2011
- Re: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/21/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/21/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, au9ustine, 11/20/2011
