cgal-discuss - Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN
  • To:
  • Cc: Vivien Clauzon <>, "Laurent Rineau (GeometryFactory)" <>
  • Subject: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN
  • Date: Fri, 18 Nov 2011 15:41:15 +0100
I Mark,
Thanks for the report. I am surprised, because I use Qt-4.8 and boost-1.47,
and the g++ compiler on Linux and I do not see that error. I would like to
reproduce the bug before I apply you patch.
- What version of Boost was involved?
boost 1.48
I think I originally reported this for boost 1.47 as well, but as Vivien points out, boost 1.47 does not even have /boost/type_traits/detail/has_binary_operator.hpp. I have checked again, and only boost 1.48 shows this problem. I guess I didn't clean up properly the first time I reverted to boost 1.47.
- And what version of mingw?
- You talk about cross-compiling? What was the target-OS, and what was the
host-OS?
This probably doesn't matter so much now that Vivien has cleared up the confusion about boost 1.47, but here it is:
mingwrt 3.20
gcc 4.6.2
I noticed the problem while updating packages in the development branch of mingw-cross-env [1]. This is an environment targetting mingw (win32) from unix. It currently has Qt 4.8.0 rc1, but after building CGAL failed, I also tried running moc from the Qt 4.7.4 opensuse RPM and got the same error.
On 11/18/2011 02:49 PM, Vivien Clauzon wrote:
Hi,
I think only boost 1.48 has a
file.
Thanks for pointing that out!
regards,
Mark
[1] http://mingw-cross-env.nongnu.org/
