- To:
- Cc: Vivien Clauzon <>, "Laurent Rineau (GeometryFactory)" <>
- Subject: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN
- Date: Fri, 18 Nov 2011 10:46:53 -0500
Hello list.
I am having the same error with CGAL-3.8, CGAL-3.9, boost 1.48 and
gcc-4.4.3 on Ubuntu.
Regards,
Panagiotis
On Fri, Nov 18, 2011 at 9:41 AM, Mark Brand
wrote:
>>> I Mark,
>>> Thanks for the report. I am surprised, because I use Qt-4.8 and
>>> boost-1.47,
>>> and the g++ compiler on Linux and I do not see that error. I would like
>>> to
>>> reproduce the bug before I apply you patch.
>>> - What version of Boost was involved?
> boost 1.48
> I think I originally reported this for boost 1.47 as well, but as Vivien
> points out, boost 1.47 does not even have
> /boost/type_traits/detail/has_binary_operator.hpp. I have checked again,
> and only boost 1.48 shows this problem. I guess I didn't clean up properly
> the first time I reverted to boost 1.47.
>>> - And what version of mingw?
>>> - You talk about cross-compiling? What was the target-OS, and what was
>>> the
>>> host-OS?
> This probably doesn't matter so much now that Vivien has cleared up the
> confusion about boost 1.47, but here it is:
> mingwrt 3.20
> gcc 4.6.2
> I noticed the problem while updating packages in the development branch of
> mingw-cross-env [1]. This is an environment targetting mingw (win32) from
> unix. It currently has Qt 4.8.0 rc1, but after building CGAL failed, I also
> tried running moc from the Qt 4.7.4 opensuse RPM and got the same error.
> On 11/18/2011 02:49 PM, Vivien Clauzon wrote:
>> Hi,
>> I think only boost 1.48 has a
>> file.
> Thanks for pointing that out!
> regards,
> Mark
> [1] http://mingw-cross-env.nongnu.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Vivien Clauzon, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Mark Brand, 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/18/2011
- Re: Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Laurent Rineau (GeometryFactory), 11/21/2011
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, Panagiotis Foteinos, 11/21/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] [PATCH] prevent Qt's moc from choking on BOOST_JOIN, au9ustine, 11/20/2011
