- To:
- Subject: [cgal-discuss] a surface mesh simple cube example
- Date: Mon, 2 Jan 2012 16:48:01 -0500
Hi,
I am trying to use points and normals to reconstruct surface mesh, I follow "Surface
Reconstruction from Point Sets" section in CGAL.
I have some input points and its normal. Since algorithm solves eliptic equation of
Poisson reconstruction and it gives a approximate surface.
Is it possible to reconstruct mesh that its vertices areĀ exactly the same with input?
if you can help me, I would be really glad,
Thanks,
B. Gazi YILDIRIM
- [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/02/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Sebastien Loriot (GeometryFactory), 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/12/2012
