cgal-discuss - Re: [cgal-discuss] a surface mesh simple cube example
  • To:
  • Subject: Re: [cgal-discuss] a surface mesh simple cube example
  • Date: Tue, 3 Jan 2012 11:23:30 -0500
Hi Sebastian,
Our problem we have a simple shape of beam (thin plate) is deforming,
one of our solver is particle based solver and it send  surface   points of
the beam to other mesh-based solver. The mesh based solver takes these points and needs
to create the surface mesh.  But we insist on the original points, otherwise we have
a lot complications.
Those points might create a concave shape, I think that convex shape is not guaranteed.
Thanks,
On Tue, Jan 3, 2012 at 11:08 AM, Sebastien Loriot (GeometryFactory) <> wrote:
Do your points have some particular properties (on a convex shape, inside a set of planes, ...)?
Sebastien.
Battalgazi YILDIRIM wrote:
Hi Sebastian,
Thanks for answer,
Is there any other way to do in CGAL, just give surface points and get reconstructed mesh
connecting those points?
Thanks,
On Tue, Jan 3, 2012 at 2:20 AM, Sebastien Loriot (GeometryFactory) < <mailto:>> wrote:
       Hi,
       I am trying to use points and normals to reconstruct surface
       mesh, I follow "Surface
       Reconstruction from Point Sets" section in CGAL.
       I have some input points and its normal. Since algorithm solves
       eliptic equation of
       Poisson reconstruction and it gives a approximate surface.
       Is it possible to reconstruct mesh that its vertices are
        exactly the same with input?
   This is not possible with this algorithm.
   Sebastien.
       if you can help me, I would be really glad,
       Thanks,
       B. Gazi YILDIRIM
   --     You are currently subscribed to cgal-discuss.
   https://lists-sop.inria.fr/__wws/info/cgal-discuss
B. Gazi YILDIRIM
