- To:
- Subject: Re: [cgal-discuss] a surface mesh simple cube example
- Date: Tue, 03 Jan 2012 17:08:07 +0100
Do your points have some particular properties (on a convex shape, inside a set of planes, ...)?
Sebastien.
Battalgazi YILDIRIM wrote:
Hi Sebastian,
Thanks for answer,
Is there any other way to do in CGAL, just give surface points and get reconstructed mesh
connecting those points?
Thanks,
On Tue, Jan 3, 2012 at 2:20 AM, Sebastien Loriot (GeometryFactory) < <mailto:>> wrote:
Hi,
I am trying to use points and normals to reconstruct surface
mesh, I follow "Surface
Reconstruction from Point Sets" section in CGAL.
I have some input points and its normal. Since algorithm solves
eliptic equation of
Poisson reconstruction and it gives a approximate surface.
Is it possible to reconstruct mesh that its vertices are
exactly the same with input?
This is not possible with this algorithm.
Sebastien.
if you can help me, I would be really glad,
Thanks,
B. Gazi YILDIRIM
-- You are currently subscribed to cgal-discuss.
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
B. Gazi YILDIRIM
- [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/02/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Sebastien Loriot (GeometryFactory), 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/12/2012
