- To:
- Subject: Re: [cgal-discuss] a surface mesh simple cube example
- Date: Tue, 3 Jan 2012 11:02:02 -0500
Hi Sebastian,
Thanks for answer,
Is there any other way to do in CGAL, just give surface points and get reconstructed mesh
connecting those points?
Thanks,
On Tue, Jan 3, 2012 at 2:20 AM, Sebastien Loriot (GeometryFactory) <> wrote:
Battalgazi YILDIRIM wrote:This is not possible with this algorithm.
Hi,
I am trying to use points and normals to reconstruct surface mesh, I follow "Surface
Reconstruction from Point Sets" section in CGAL.
I have some input points and its normal. Since algorithm solves eliptic equation of
Poisson reconstruction and it gives a approximate surface.
Is it possible to reconstruct mesh that its vertices are exactly the same with input?
Sebastien.--
if you can help me, I would be really glad,
Thanks,
B. Gazi YILDIRIM
B. Gazi YILDIRIM
- [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/02/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Sebastien Loriot (GeometryFactory), 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/12/2012
