- To:
- Subject: Re: [cgal-discuss] a surface mesh simple cube example
- Date: Tue, 03 Jan 2012 19:15:53 +0100
One thing you can try is the Alpha_shape_3 demo
(in CGAL_ROOT/demo/Alpha_shape_3) and play with the slider to see
whether the reconstruction fit your needs.
Sebastien.
Battalgazi YILDIRIM wrote:
Hi Sebastian,
Our problem we have a simple shape of beam (thin plate) is deforming,
one of our solver is particle based solver and it send surface points of
the beam to other mesh-based solver. The mesh based solver takes these points and needs
to create the surface mesh. But we insist on the original points, otherwise we have
a lot complications.
Those points might create a concave shape, I think that convex shape is not guaranteed.
Thanks,
On Tue, Jan 3, 2012 at 11:08 AM, Sebastien Loriot (GeometryFactory) < <mailto:>> wrote:
Do your points have some particular properties (on a convex shape,
inside a set of planes, ...)?
Sebastien.
Hi Sebastian,
Thanks for answer,
Is there any other way to do in CGAL, just give surface points
and get reconstructed mesh
connecting those points?
Thanks,
On Tue, Jan 3, 2012 at 2:20 AM, Sebastien Loriot
(GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>
Hi,
I am trying to use points and normals to reconstruct surface
mesh, I follow "Surface
Reconstruction from Point Sets" section in CGAL.
I have some input points and its normal. Since algorithm
solves
eliptic equation of
Poisson reconstruction and it gives a approximate surface.
Is it possible to reconstruct mesh that its vertices are
exactly the same with input?
This is not possible with this algorithm.
Sebastien.
if you can help me, I would be really glad,
Thanks,
B. Gazi YILDIRIM
-- You are currently subscribed to cgal-discuss.
https://lists-sop.inria.fr/____wws/info/cgal-discuss
<https://lists-sop.inria.fr/__wws/info/cgal-discuss>
<https://lists-sop.inria.fr/wws/info/cgal-discuss>>
-- B. Gazi YILDIRIM
B. Gazi YILDIRIM
- [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/02/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Sebastien Loriot (GeometryFactory), 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/03/2012
- Re: [cgal-discuss] a surface mesh simple cube example, Battalgazi YILDIRIM, 01/12/2012
