- To:
- Subject: Re: [cgal-discuss] Re: Mesh generation question
- Date: Mon, 23 Jan 2012 17:27:32 +0100
Le jeudi 19 janvier 2012 09:30:53 Ram a écrit :
> I extracted the output by creating a .vtk file and visualizing it using vtk.
> The iterator lines are:
> Function: template < class GT, class TDS > void
> show_triangulation_edges(std::ofstream &gv, const Triangulation_3<GT,TDS>
> &T)
> Iterations:
> Vertices: for( typename Triangulation_3<GT, TDS>::Finite_vertices_iterator
> vit = T.finite_vertices_begin(); vit != T.finite_vertices_end(); ++vit)
> Tetrahedrons:
> for( typename Triangulation_3<GT, TDS>::Finite_cells_iterator
> cit = T.finite_cells_begin(); cit != T.finite_cells_end(); ++cit)
> The call to function is done here:
> // Triangulation access
> MyTriangulation T = c3t3.triangulation();
> std::ofstream myfile;
> myfile.open("example.vtk");
> CGAL::show_triangulation_edges(myfile, T);
> myfile.close();
> Wired things happen when I visualize the output. One problem is skinny
> triangles. The other problem I've seen is when I mesh a cube, some faces
> have small triangles, but others have very large triangles.
> With some mesh criterion, I do see graded meshes all around.
You outputs all the cells of the triangulation. Instead, you should output
only the cells of the c3t3:
for(typename C3t3::Cells_in_complex_iterator
cit = c3t3.cells_in_complex_begin();
cit != cells_in_complex_end(); ++cit)
Laurent Rineau, PhD
- [cgal-discuss] Re: Mesh generation question, (continued)
- [cgal-discuss] Re: Mesh generation question, Ram, 01/18/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/18/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/19/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/19/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/23/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/21/2012
