- To:
- Subject: [cgal-discuss] Re: Mesh generation question
- Date: Wed, 18 Jan 2012 12:06:30 -0800 (PST)
Another problem I see is this: When I use:
// Mesh criteria (no cell_size set)
Mesh_criteria criteria(facet_angle=30.0, facet_size=100.0,
cell_radius_edge=2);
on a cube polyhedron, I get the attached picture as output:
http://cgal-discuss.949826.n4.nabble.com/file/n4307908/Capture.JPG
Why are the triangles not respecting the 30 degree angle bound I put on
them? How can I fix this? (I want all my triangles to have angles say
greater than 10 degrees). Is that possible to do? With what mesh criterion?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-generation-question-tp4300233p4307908.html
- Re: [cgal-discuss] Mesh generation question, (continued)
- Re: [cgal-discuss] Mesh generation question, Laurent Rineau (GeometryFactory), 01/16/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/16/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/17/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/18/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/18/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/19/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/19/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/21/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/23/2012
