- To:
- Subject: Re: [cgal-discuss] merging 3d meshes
- Date: Mon, 06 Feb 2012 09:12:40 +0100
I think more details are needed to give you an answer.
Do the boundaries of your polyhedral domains intersect?
Can you elaborate on what is the desired output of the merge (maybe with a 2D example if possible)?
Have you try to mesh all the polyhedral domains at once?
Sebastien.
On 02/04/2012 04:36 PM, arnola79 wrote:
Hello,
I use CGAL to mesh several polyhedral domains. Now, I would like to merge
these domains. Is it possible to do it? If yes, could i retrieve each entity
in order to apply different properties in a fem analysis?
Thank you!
Best Regards
A. Alzina
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/merging-3d-meshes-tp4357251p4357251.html
- [cgal-discuss] merging 3d meshes, arnola79, 02/04/2012
- Re: [cgal-discuss] merging 3d meshes, Sebastien Loriot (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/06/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/09/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/10/2012
- Re: Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/10/2012
