- To:
- Subject: [cgal-discuss] Re: merging 3d meshes
- Date: Mon, 6 Feb 2012 06:03:19 -0800 (PST)
"Do the boundaries of your polyhedral domains intersect? "
Indeed, boundaries of my polyhedral domains intersect (image).
"Can you elaborate on what is the desired output of the merge (maybe with a
2D example if possible)? "
i tried to do a diagram wich explain my problem (image).
"Have you try to mesh all the polyhedral domains at once? "
Not yet because i thought there would be problems with boundaries.
http://cgal-discuss.949826.n4.nabble.com/file/n4361310/3Dmesh.png
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/merging-3d-meshes-tp4357251p4361310.html
- [cgal-discuss] merging 3d meshes, arnola79, 02/04/2012
- Re: [cgal-discuss] merging 3d meshes, Sebastien Loriot (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/06/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/09/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/10/2012
- Re: Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/10/2012
