cgal-discuss - Re: Re: Re: [cgal-discuss] Re: merging 3d meshes
  • To:
  • Subject: Re: Re: Re: [cgal-discuss] Re: merging 3d meshes
  • Date: Thu, 09 Feb 2012 11:47:55 +0100
Le mercredi 08 février 2012 10:47:00 Arnaud A. a écrit :
> Thank you for your help, il will try your solution...
> When you said "You said the boundaries of your two polyhedra intersect, but
> they do not. ", it was true. Actually, there are several "copeau" files
> (approximately 200). For example, i want to make a fuse between copeau.mesh
> and copeau1.mesh then make a cut between conteneur.mesh and the result of
> the fuse.
> Is it still possible?
It is hard to produce a correct mesh in that case. Using the Multi_domain_*
class, you will get a mesh, but the mesh will be a bit fuzzy around the
intersection lines of your "copeaux": in mesh the intersection line will not
be strait but irregular, like that:
Laurent Rineau, PhD
