- To:
- Subject: Re: [cgal-discuss] Re: merging 3d meshes
- Date: Mon, 06 Feb 2012 16:28:23 +0100
Le lundi 06 février 2012 06:03:19 Arnaud A. a écrit :
> "Do the boundaries of your polyhedral domains intersect? "
> Indeed, boundaries of my polyhedral domains intersect (image).
> "Can you elaborate on what is the desired output of the merge (maybe with a
> 2D example if possible)? "
> i tried to do a diagram wich explain my problem (image).
> "Have you try to mesh all the polyhedral domains at once? "
> Not yet because i thought there would be problems with boundaries.
> http://cgal-discuss.949826.n4.nabble.com/file/n4361310/3Dmesh.png
Can you send us a data set with two such polyhedral domains?
Laurent Rineau, PhD
- [cgal-discuss] merging 3d meshes, arnola79, 02/04/2012
- Re: [cgal-discuss] merging 3d meshes, Sebastien Loriot (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/06/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/09/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/10/2012
- Re: Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/10/2012
