cgal-discuss - Re: [cgal-discuss] Error in CMake Configuration
  • To:
  • Subject: Re: [cgal-discuss] Error in CMake Configuration
  • Date: Sat, 21 Apr 2012 09:44:51 +0300
Thank you all for your help. I did that and it worked perfectly. However, when I check the box where it says with demos or the one says with examples am getting this kind of error:
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:64 (FILE):
file problem creating directory: C:/Program Files
(x86)/CGAL-3.9/demo/C:/Program Files (x86)/CGAL-3.9/demo/Triangulation_2
Call Stack (most recent call first):
C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:200 (QT4_MAKE_OUTPUT_FILE)
demo/Triangulation_2/CMakeLists.txt:88 (qt4_add_resources)
CMake Error: Could not open file for write in copy operation C:/Program Files (x86)/CGAL-3.9/demo/C:/Program Files (x86)/CGAL-3.9/demo/Triangulation_2.tmp
CMake Error: : System Error: Invalid argument
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:201 (CONFIGURE_FILE):
configure_file Problem configuring file
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:111 (FILE):
file Internal CMake error when trying to open file: C:/Program Files
(x86)/CGAL-3.9/demo/Triangulation_2/Regular_triangulation_2.moc_parameters
for writing.
C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:134 (QT4_CREATE_MOC_COMMAND)
demo/Triangulation_2/CMakeLists.txt:91 (qt4_generate_moc)
Any ideas??
Thanks
On 17 April 2012 18:14, Jasmin Formont <> wrote:
I had this problem too, setting BOOST_ROOT was not enough, I had to set BOOST_LIBDIR to make Cmake happy.
2012/4/17 Zoltán Váradi <>
"No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost."
As it says, you should set the Boost_LIBRARYDIR or BOOST_ROOT in your path.This tutorial tells you how:http://geekswithblogs.net/renso/archive/2009/10/21/how-to-set-the-windows-path-in-windows-7.aspx
2012. április 17. 16:49 Laurent Rineau (GeometryFactory) írta, <>:
Le mardi 17 avril 2012 17:39:10 Sweety Pie a écrit :
> Dear all,
> Can you please check the following errors am getting while configuring the
> Cmake with VS10 to compile the CGAL libraries:
> _
> CMake Error at cmake/modules/FindBoost.cmake:515 (FILE):
> (x86)/boost/boost/version.hpp for reading.
Do you have a file "C:/Program Files (x86)/boost/boost/version.hpp"?
If the CMake cache, do you have anything about Boost?
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
