- To:
- Subject: [cgal-discuss] Re: Error in CMake Configuration
- Date: Tue, 24 Apr 2012 06:01:00 -0700 (PDT)
I saw that and did switch my binaries directory to
C:/User/MyName/Documents/CGAL, but I'm still having the same issue:
*Internal CMake error when trying to open file:
C:/Users/MyName/Documents/CGAL/demo/C:/Program Files
(x86)/CGAL-4.0/demo/Triangulation_3/Viewer.moc_parameters for writing.*
I've deleted the cache file, and actually even deleted and reinstalled the
CGAL source code to try to eliminate any residual settings that would have
been messed up by initially having the binary directories set to Program
Files (x86), but still get the same error.
Laurent Rineau (GeometryFactory) wrote
> I have already said that you should never try to use something inside C:
> \Program Files*\ as binary directory for CMake.
> Keep CGAL sources in C:/Program Files (x86)/ but use something in your
> user
> Document directory as binary directory.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-in-CMake-Configuration-tp4564931p4583376.html
- [cgal-discuss] Error in CMake Configuration, Sweety Pie, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Zoltán Váradi, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Jasmin Formont, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Sweety Pie, 04/21/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/23/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/23/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/24/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/24/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/25/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Sweety Pie, 04/29/2012
