Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10
- To:
- Subject: Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10
- Date: Wed, 25 Apr 2012 08:01:49 +0200
Le 25/04/2012 05:45, stupormundi a écrit :
I realized that cmake indicated that it DID find the libs:
-- Found QGLViewer: /usr/lib/x86_64-linux-gnu/libqglviewer-qt4.so
I then checked CMakeCache.txt and found these entries :
//Path to a file.
QGLVIEWER_INCLUDE_DIR:PATH=/usr/include
//The QGLViewer library
QGLVIEWER_LIBRARIES:FILEPATH=/usr/lib/x86_64-linux-gnu/libqglviewer-qt4.so
//Path to a library.
QGLVIEWER_LIBRARY_DEBUG:FILEPATH=QGLVIEWER_LIBRARY_DEBUG-NOTFOUND
QGLVIEWER_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libqglviewer-qt4.so
and :
//Path to a file.
QT_QTOPENGL_INCLUDE_DIR:PATH=/usr/include/qt4/QtOpenGL
//The Qt QTOPENGL library
QT_QTOPENGL_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtOpenGL.so
QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND
QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtOpenGL.so
To compare, the complaint from make is :
make[2]: *** No rule to make target `/usr/lib/libQtOpenGL.so', needed by
`AABB_tree/AABB_demo'. Stop.
Apparently the error means make thinks it needs to build that target. I
don't know why make would think so. Would the reason be that
QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND ?
No.
It would seem cmake found all the libs but not the debug lib? should that be
the same file?
No. It only means that you do not have the debugging symbol for the QtOpenGL library (thus you cannot debug this library).
But this is not a problem to compile and link CGAL demo. I think the
Did you check the CMakeCache.txt of the library or in the demo directory ?
Did you try to clean all the build directory and restart from a proper new install ?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-making-CGAL-demos-libQtOpenGL-on-Ubuntu-11-10-tp4579052p4585523.html
Guillaume DAMIAND
CNRS, LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
- [cgal-discuss] Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/23/2012
- Re: [cgal-discuss] Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Sebastien Loriot (GeometryFactory), 04/23/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/24/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/25/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Guillaume Damiand, 04/25/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Laurent Rineau (GeometryFactory), 04/25/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Guillaume Damiand, 04/24/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/28/2012
- [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, stupormundi, 04/29/2012
- Re: [cgal-discuss] Re: Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10, Guillaume Damiand, 04/30/2012
