cgal-discuss - Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • To:
  • Subject: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • Date: Thu, 24 May 2012 15:10:26 +0200 (CEST)
you have to rename the libgmp that is provided in the directory "Auxilary" with this name. I remind that i had to change 2 lib names (v -10 et -4 i guess)
As far as i am concerned, i have too many problems with the 64 bits version, so i installed the 32 bits one and it works .... (with VS2010)
gwenaelle
De: "Sweety Pie" <>
À:
Envoyé: Mercredi 23 Mai 2012 23:27:37
Objet: Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
I did that just know and guess what?? I got this error in the VS proj:
The program can't start because libgmp-10.dll is missing from your computer.
One thing I need to mention here: Using CGAL 32-bit version in a 64-bit machine, will it have any effect on the project?? I mean the 64-bit machine should handle both the 32 and the 64 versions or not?
On 24 May 2012 00:09, Eugen Funk <> wrote:
try setting your PATH environment variable to the directory CGAL/lib
:) Maybe this helps?
2012/5/23 Sweety Pie <>
I checked the environment var and all are all-right. Which lib path should point to (cgal-vc100...) libs ??
I did compile CGAL in the debug mode and uninstall and reinstall it several times but with it was not useful.
On 22 May 2012 08:42, Eugen Funk <> wrote:
check your path environment var.
and the created cgalconfig.cmake
the library paths should point to your (cgal-vc100...) libs.
make sure to have compiled cgal in debug mode.
if something is wrong, uninstall all versions of cgal, install yours and run cmake again.
Am 22.05.2012 03:19 schrieb "flavio.anjos" <>:
Well, if you installed everything correctly ... What impresses me is "0
failed" was to have worked ... Really, now do not know what may have caused
it ... Maybe some way of libs placed wrong ... I do not know ... on my
machine:
In Visual Studio in Vc + + directories:
C: \ Program Files x86 \ boost \ boost_1_44
C: \ CGAL-3.9 \ include
C: \ CGAL-3.9 \ auxiliary \ gmp \ include
C: \ CGAL-3.9 \ auxiliary \ taucs \ include
C: \ CGAL-3.9 \ auxiliary \ gdb
compiled in both installation (Debug and Release)before programming...
Now, is not it, really do not know (open a new topic for staff to help you
best regards
Flávio dos Anjos
View this message in context: http://cgal-discuss.949826.n4.nabble.com/The-program-can-t-start-because-CGAL-vc100-mt-gd-4-0-dll-is-missing-tp4646649p4649179.html
