cgal-discuss - Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • To:
  • Subject: Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • Date: Thu, 31 May 2012 14:06:34 +0300
OOOPS I admit I should noticed that there is no GUI provided but at
least there should be a cout sentence in the VS output screen or there
shouldn't be?
On 31 May 2012 14:01, Andreas Fabri
wrote:
> Sweety Pie,
> Do you really know what you can and want to do with CGAL?
> CGAL is NOT an application, but a library with C++ classes
> and functions that can be used to solve low level geometric
> problems.
> The examples have no GUI, and their only purpose is to
> illustrate how to use the API.  You should read the
> examples before you start them, as there are examples that
> read input from std::cin (please don't ask me what std::cin is).
> best regards,
> andreas
> On 31/05/2012 12:35, Philipp Moeller wrote:
>> Sweety
>> Pie<>
>>  writes:
>>> Sorry, my fault, I found the .exe file but when I double click on it,
>>> it just starts and in microseconds closes. I can even see what is
>>> written on the screen :( any ideas why??
>> Use the command prompt to launch the executable. Or Ctrl + F5 in Visual
>> Studio should work to.
>>> On 31 May 2012 12:29, Sweety
>>> Pie<>
>>>  wrote:
>>>> Well I went to the CGAL folder located on my C: drive and found a
>>>> folder called constrained.dir
>>>> inside there is the Debug folder but there r no .exe files!!!
>>>> Did I searched in the wrong place or what?
>>>> On 31 May 2012 12:22, Sebastien Loriot (GeometryFactory)
>>>>  wrote:
>>>>> He meant did you try running the .exe file that is created during the
>>>>> compilation?
>>>>> Sebastien.
>>>>> On 05/31/2012 11:01 AM, Sweety Pie wrote:
>>>>>> Thanks for the reply but am afraid I didn't get what do you mean by
>>>>>> the created executable?? :(
>>>>>> On 31 May 2012 11:27, Philipp Moeller
>>>>>>    wrote:
>>>>>>> Sweety
>>>>>>> Pie<>
>>>>>>>    writes:
>>>>>>>> Dear all,
>>>>>>>> Am running the code of the Constrained Delaunay triangulation
>>>>>>>> example
>>>>>>>> provided by CGAL. After building it is shows  Rebuild All: 1
>>>>>>>> succeeded
>>>>>>>> at the end but there is no output shown. It even doesn't lunch any
>>>>>>>> additional screens or anything. Any idea why??
>>>>>>>> Thanks for your help,
>>>>>>> This might be obvious: Did you launch the created executable after
>>>>>>> building it?
>>>>>>> Cheers,
>>>>>>> Philipp Moeller
>>>>>>> GeometryFactory
>>>>>>> You are currently subscribed to cgal-discuss.
>>>>>>> To unsubscribe or access the archives, go to
>>>>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: +33.492.954.912    skype: andreas.fabri
