cgal-discuss - Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • To:
  • Subject: Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • Date: Thu, 31 May 2012 14:11:13 +0300
THANK YOU Clément Jamin. Your suggestion worked perfectly :)
On 31 May 2012 14:06, Clément Jamin
wrote:
> On Thu, May 31, 2012 at 12:35 PM, Philipp Moeller
> wrote:
>> Sweety Pie
>> writes:
>>> Sorry, my fault, I found the .exe file but when I double click on it,
>>> it just starts and in microseconds closes. I can even see what is
>>> written on the screen :( any ideas why??
>> Use the command prompt to launch the executable. Or Ctrl + F5 in Visual
>> Studio should work to.
> Before doing that, in the "Solution explorer" in VC++, you can see
> several "projects" (ALL_BUILD, an_example, ZERO_CHECK). Right-click on
> an_example and click "Set as StartUp project".
> Now you can use Ctrl+F5 to launch the example.
>>> On 31 May 2012 12:29, Sweety Pie
>>> wrote:
>>>> Well I went to the CGAL folder located on my C: drive and found a
>>>> folder called constrained.dir
>>>> inside there is the Debug folder but there r no .exe files!!!
>>>> Did I searched in the wrong place or what?
>>>> On 31 May 2012 12:22, Sebastien Loriot (GeometryFactory)
>>>> wrote:
>>>>> He meant did you try running the .exe file that is created during the
>>>>> compilation?
>>>>> Sebastien.
>>>>> On 05/31/2012 11:01 AM, Sweety Pie wrote:
>>>>>> Thanks for the reply but am afraid I didn't get what do you mean by
>>>>>> the created executable?? :(
>>>>>> On 31 May 2012 11:27, Philipp Moeller
>>>>>>  wrote:
>>>>>>> Sweety
>>>>>>> Pie<>
>>>>>>>  writes:
>>>>>>>> Dear all,
>>>>>>>> Am running the code of the Constrained Delaunay triangulation example
>>>>>>>> provided by CGAL. After building it is shows  Rebuild All: 1
>>>>>>>> succeeded
>>>>>>>> at the end but there is no output shown. It even doesn't lunch any
>>>>>>>> additional screens or anything. Any idea why??
>>>>>>>> Thanks for your help,
>>>>>>> This might be obvious: Did you launch the created executable after
>>>>>>> building it?
>>>>>>> Cheers,
>>>>>>> Philipp Moeller
>>>>>>> GeometryFactory
>>>>>>> You are currently subscribed to cgal-discuss.
>>>>>>> To unsubscribe or access the archives, go to
>>>>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
