cgal-discuss - Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • To:
  • Subject: Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • Date: Thu, 31 May 2012 13:06:02 +0200
On Thu, May 31, 2012 at 12:35 PM, Philipp Moeller
wrote:
> Sweety Pie
> writes:
>> Sorry, my fault, I found the .exe file but when I double click on it,
>> it just starts and in microseconds closes. I can even see what is
>> written on the screen :( any ideas why??
> Use the command prompt to launch the executable. Or Ctrl + F5 in Visual
> Studio should work to.
Before doing that, in the "Solution explorer" in VC++, you can see
several "projects" (ALL_BUILD, an_example, ZERO_CHECK). Right-click on
an_example and click "Set as StartUp project".
Now you can use Ctrl+F5 to launch the example.
>> On 31 May 2012 12:29, Sweety Pie
>> wrote:
>>> Well I went to the CGAL folder located on my C: drive and found a
>>> folder called constrained.dir
>>> inside there is the Debug folder but there r no .exe files!!!
>>> Did I searched in the wrong place or what?
>>> On 31 May 2012 12:22, Sebastien Loriot (GeometryFactory)
>>> wrote:
>>>> He meant did you try running the .exe file that is created during the
>>>> compilation?
>>>> Sebastien.
>>>> On 05/31/2012 11:01 AM, Sweety Pie wrote:
>>>>> Thanks for the reply but am afraid I didn't get what do you mean by
>>>>> the created executable?? :(
>>>>> On 31 May 2012 11:27, Philipp Moeller
>>>>>  wrote:
>>>>>> Sweety
>>>>>> Pie<>
>>>>>>  writes:
>>>>>>> Dear all,
>>>>>>> Am running the code of the Constrained Delaunay triangulation example
>>>>>>> provided by CGAL. After building it is shows  Rebuild All: 1 succeeded
>>>>>>> at the end but there is no output shown. It even doesn't lunch any
>>>>>>> additional screens or anything. Any idea why??
>>>>>>> Thanks for your help,
>>>>>> This might be obvious: Did you launch the created executable after
>>>>>> building it?
>>>>>> Cheers,
>>>>>> Philipp Moeller
>>>>>> GeometryFactory
>>>>>> You are currently subscribed to cgal-discuss.
>>>>>> To unsubscribe or access the archives, go to
>>>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
