cgal-discuss - Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed
  • To:
  • Subject: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed
  • Date: Wed, 6 Jun 2012 16:31:27 +0530
Adding the following lines to CGAL_SetupBoost.cmake fixed my error
  set(Boost_USE_STATIC_LIBS   ON)
  set(Boost_USE_MULTITHREADED ON)
  set(Boost_ADDITIONAL_VERSIONS "1.47")
On Wed, Jun 6, 2012 at 3:39 PM, Devashish Tyagi <> wrote:
I followed your tutorial and tried installing CGAL 4.0 beta1 on my 32 bit windows machine. When I ran cmake configure I encountered the following error
CMake Error at cmake/modules/FindBoost.cmake:917 (message):
Unable to find the requested Boost libraries.
Boost version: 1.47.0
Boost include path: C:/Program Files/boost/boost_1_47
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:32 (include)
CMakeLists.txt:455 (include)
On Mon, Jun 4, 2012 at 6:51 PM, Sebastien Loriot (GeometryFactory) <> wrote:
Hello CGAL users,
Due to the increasing traffic on this list about installation issues on
Windows, we decided to come up with a dedicated tutorial.
In order to make it better, we would like people to read/try it
and send feedback (typos, what did not work, what can be improved, ...).
You can send it to the list or directly to me if you prefer.
The current address of the page is:
http://www.cgal.org/windows_installation.html
Thanks for your help,
Sebastien.
Devashish Tyagi
Junior Undergraduate
Computer Science and Engineering Dept.
IIT Delhi
Devashish Tyagi
IIT Delhi
