- To:
- Subject: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed
- Date: Mon, 11 Jun 2012 11:47:24 +0200
"Laurent Rineau (CGAL/GeometryFactory)"
writes:
> Le samedi 09 juin 2012 16:35:18 Philipp Moeller a écrit :
>> Sweety Pie
>> writes:
>> > Please note that CMake GUI should be Run as Administrator for Win7
>> No, it shouldn't. This is only the case when file permissions or
>> installation folders have been chosen poorly.
>> Running build systems as root is dangerous.
> I think the tutorial should be more precise about that. In my opinion, if
> the
> user account is not an "administrator account", the tutorial should tell
> that
> the CGAL binary directory must be in the user directory.
Isn't that a too strict restriction? Build as user and install as root
should work well, too.
We could also try to implement a check for the validity of the selected
install directories at configuration time and issue a hint that the
install target requires elevated privileges. Although, I see no way to
get permissions of a directory from within CMake. We can always do funny
things, e.g. trying to copy a file and check for the outcome, but I'm
afraid that will lead to strange/scary results with UAC enabled.
- [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/04/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Devashish Tyagi, 06/06/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/07/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sweety Pie, 06/09/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/09/2012
- Re: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Laurent Rineau (CGAL/GeometryFactory), 06/11/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/11/2012
- RE: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Max, 06/09/2012
- [cgal-discuss] RE: Tutorial to install CGAL on Windows: Feedback needed, edward, 06/09/2012
