- To:
- Subject: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed
- Date: Sat, 9 Jun 2012 17:33:27 +0300
Please note that CMake GUI should be Run as Administrator for Win7
This is needed to be added to the tutorial which is really helpful.
On 7 June 2012 11:11, Sebastien Loriot (GeometryFactory)
wrote:
> Thanks for the feedback.
> OK, I found the problem.
> Variants to be selected must be:
> Multithreaded debug DLL
> Multithreaded DLL
> Multithreaded debug
> Multithreaded
> Then you need to set:
> BOOST_INCLUDEDIR=C:\Program Files (x86)\boost\boost_1_47
> BOOST_LIBRARYDIR=C:\Program Files (x86)\boost\boost_1_47\lib
> and to append to your PATH C:\Program Files (x86)\boost\boost_1_47\lib;
> Then no cmake modifications are needed.
> Sebastien.
> On 06/06/2012 01:01 PM, Devashish Tyagi wrote:
>> Adding the following lines to CGAL_SetupBoost.cmake fixed my error
>> set(Boost_USE_STATIC_LIBS ON)
>> set(Boost_USE_MULTITHREADED ON)
>> set(Boost_ADDITIONAL_VERSIONS "1.47")
>> On Wed, Jun 6, 2012 at 3:39 PM, Devashish Tyagi
>> <mailto:>>
>> wrote:
>> I followed your tutorial and tried installing CGAL 4.0 beta1 on my
>> 32 bit windows machine. When I ran cmake configure I encountered the
>> following error
>> CMake Error at cmake/modules/FindBoost.cmake:917 (message):
>> Unable to find the requested Boost libraries.
>> Boost version: 1.47.0
>> Boost include path: C:/Program Files/boost/boost_1_47
>> The following Boost libraries could not be found:
>> boost_thread
>> No Boost libraries were found. You may need to set Boost_LIBRARYDIR
>> to the
>> directory containing Boost libraries or BOOST_ROOT to the location of
>> Boost.
>> Call Stack (most recent call first):
>> cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
>> cmake/modules/CGAL_SetupDependencies.cmake:32 (include)
>> CMakeLists.txt:455 (include)
>> On Mon, Jun 4, 2012 at 6:51 PM, Sebastien Loriot (GeometryFactory)
>> <mailto:>>
>> wrote:
>> Hello CGAL users,
>> Due to the increasing traffic on this list about installation
>> issues on
>> Windows, we decided to come up with a dedicated tutorial.
>> In order to make it better, we would like people to read/try it
>> and send feedback (typos, what did not work, what can be
>> improved, ...).
>> You can send it to the list or directly to me if you prefer.
>> The current address of the page is:
>> http://www.cgal.org/windows___installation.html
>> <http://www.cgal.org/windows_installation.html>
>> Thanks for your help,
>> Sebastien.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/__wws/info/cgal-discuss
>> <https://lists-sop.inria.fr/wws/info/cgal-discuss>
>> Devashish Tyagi
>> Junior Undergraduate
>> Computer Science and Engineering Dept.
>> IIT Delhi
>> Devashish Tyagi
>> IIT Delhi
- [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/04/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Devashish Tyagi, 06/06/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/07/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sweety Pie, 06/09/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/09/2012
- Re: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Laurent Rineau (CGAL/GeometryFactory), 06/11/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/11/2012
- RE: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Max, 06/09/2012
- [cgal-discuss] RE: Tutorial to install CGAL on Windows: Feedback needed, edward, 06/09/2012
