- To:
- Subject: Re: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed
- Date: Mon, 11 Jun 2012 13:42:43 +0200
Le lundi 11 juin 2012 11:47:24 Philipp Moeller a écrit :
> "Laurent Rineau (CGAL/GeometryFactory)"
> writes:
> > Le samedi 09 juin 2012 16:35:18 Philipp Moeller a écrit :
> >> Sweety Pie
> >> writes:
> >> > Please note that CMake GUI should be Run as Administrator for Win7
> >> No, it shouldn't. This is only the case when file permissions or
> >> installation folders have been chosen poorly.
> >> Running build systems as root is dangerous.
> > I think the tutorial should be more precise about that. In my opinion, if
> > the user account is not an "administrator account", the tutorial should
> > tell that the CGAL binary directory must be in the user directory.
> Isn't that a too strict restriction? Build as user and install as root
> should work well, too.
I think that the tutorial itself does not tell anything about the
installation
of the binaries, once built. Anyway, I was talking about the binary
directory,
that is the directory where the binaries are built. The installation
directory
(referred as CMAKE_INSTALL_PREFIX in CMake) is a different story.
Maybe the tutorial could document that installation part, the only one that
may need the administrative privileges. But the installation on Windows, if
CMake creates a Visual Studio solution, is done by Visual Studio itself, as a
special target of the solution. I do not like the idea that Visual Studio is
run with administrative privileges.
> We could also try to implement a check for the validity of the selected
> install directories at configuration time and issue a hint that the
> install target requires elevated privileges. Although, I see no way to
> get permissions of a directory from within CMake. We can always do funny
> things, e.g. trying to copy a file and check for the outcome, but I'm
> afraid that will lead to strange/scary results with UAC enabled.
You are right that it would be a bad idea.
Laurent Rineau, PhD
- [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/04/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Devashish Tyagi, 06/06/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/07/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sweety Pie, 06/09/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/09/2012
- Re: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Laurent Rineau (CGAL/GeometryFactory), 06/11/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/11/2012
- RE: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Max, 06/09/2012
- [cgal-discuss] RE: Tutorial to install CGAL on Windows: Feedback needed, edward, 06/09/2012
