cgal-discuss - Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • To:
  • Subject: Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • Date: Wed, 20 Jun 2012 18:16:09 +0300
We essentially did that with Dror, and we get the error messages listed in
his email (see the end).
So for me the question is why we get these errors....
- m.
On 20 Jun 2012, at 17:55, Sebastien Loriot (GeometryFactory) wrote:
> Try:
> "cmake -DEIGEN3_INCLUDE_DIR=/Users/drorata/Library/eigen3.1.0-rc1 ."
> There should be no need to do something else for the demo.
> This was documented on that page:
> http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_10.4
> Sebastien.
> On 06/20/2012 04:19 PM,
> wrote:
>> I have installed *CGAL 4.0* on a Mac OS 10.6 using *macports*. As a test
>> case, I tried to compile the example given in /Triangulation_2/, using the
>> standard procedure:
>> - cgal_create_cmake_script
>> - cmake .
>> - make
>> This worked like a charm and suggests, if I understand it correctly, that
>> CGAL's installation is OK.
>> Next, I wanted to compile and consider the example
>> /Surface_reconstruction_points_3/. Here things got messy. I'll try to
>> describe the steps I took (some of them with the great help of Menelaos
>> Karavelas and Michael Hemmer. Thank you Menelaos and MIchael) in order to
>> resolve the issue.
>> The version of Eigen shipped with the CGAL installation through macports is
>> old, and thus I downloaded manually the latest version of eigen
>> (3.1.0-rc1).
>> In addition, I added the following line to the CMakeLists.txt:
>> include_directories (BEFORE "~/Library/eigen3.1.0-rc1/")
>> where ~/Library/eigen3.1.0-rc1/ is where the file
>> "signature_of_eigen3_matrix_library" is located.
>> This should make sure that eigen will be looked for in the right location.
>> Then I added
>> #define CGAL_EIGEN3_ENABLED
>> to the example "poisson_reconstruction_example.cpp". Finally, I ran:
>> - cmake .
>> - make poisson_reconstruction_example
>> Then I got the following compilation error:
>> ---Compilation Error Cite---
>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h: In copy
>> constructor
>> ‘Eigen::IterativeSolverBase<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> >
>>> ::IterativeSolverBase(const
>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’:
>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/IterativeLinearSolvers/
>> IterativeSolverBase.h:37: instantiated from ‘bool
>> CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function()
>> [with
>> Gt = CGAL::Epick]’
>> /Users/drorata/Documents/academics/programing/CGAL/
>> Surface_reconstruction_points_3_CGAL_4/poisson_reconstruction_example.cpp:65:
>> instantiated from here
>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h:113:
>> error:
>> ‘Eigen::internal::noncopyable::noncopyable(const
>> Eigen::internal::noncopyable&)’ is private
>> IterativeSolverBase.h:37: error: within this context
>> ConjugateGradient.h: In copy constructor
>> ‘Eigen::ConjugateGradient<Eigen::SparseMatrix<double, 0, int>, 1,
>> Eigen::DiagonalPreconditioner<double> >::ConjugateGradient(const
>> Eigen::DiagonalPreconditioner<double> >&)’:
>> ConjugateGradient.h:160: instantiated from ‘bool
>> [with
>> Gt = CGAL::Epick]’
>> ConjugateGradient.h:160: note: synthesized method
>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’ first required
>> here
>> /opt/local/include/CGAL/Eigen_solver_traits.h: In copy constructor
>> ‘CGAL::Eigen_solver_traits<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
>>> ::Eigen_solver_traits(const
>> /opt/local/include/CGAL/Eigen_solver_traits.h:58: instantiated from ‘bool
>> [with
>> Gt = CGAL::Epick]’
>> /opt/local/include/CGAL/Eigen_solver_traits.h:58: note: synthesized method
>> Eigen::DiagonalPreconditioner<double> >&)’ first required here
>> /opt/local/include/CGAL/Poisson_reconstruction_function.h: In member
>> function
>> ‘bool
>> [with Gt = CGAL::Epick]’:
>> /opt/local/include/CGAL/Poisson_reconstruction_function.h:264: note:
>> synthesized method
>> here
>> make[3]: *** [CMakeFiles/poisson_reconstruction_example.dir/
>> poisson_reconstruction_example.cpp.o] Error 1
>> make[2]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2
>> make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/rule] Error 2
>> make: *** [poisson_reconstruction_example] Error 2
>> ---Compilation Error END---
>> I am unable to find what the problem is? Seems like it is either a problem
>> in
>> EIGEN, or the way it is being using in CGAL/this specific example.
>> If further details regarding my setting etc. is needed please let me know.
>> Thanks in advance!
>> Dror Atariah
>> PS: I'm in Chapel Hill till tomorrow, so if you're around I'm available to
>> have a look at the problem together.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
