cgal-discuss - Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • To:
  • Subject: Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • Date: Fri, 22 Jun 2012 15:08:28 +0200
On 06/22/2012 02:59 PM, Dror Atariah wrote:
Well, I compiled the example using the alpha version of eigen and obtained an
executable (i.e. no compilation errors were generated). Then I tried to run it and go
the "Segmentation fault".
Let me know what further details can I provide?
You mean the application crashes at start up or when you try to run a reconstruction?
Could you give information about you system (MacOS version, compiler, version of QT,...)
Thanks,
Sebastien.
All the best,
Dror
On Jun 21, 2012, at 08:01 AM, Sebastien Loriot (GeometryFactory) wrote:
On 06/20/2012 06:55 PM, Dror Atariah wrote:
This indeed solved the problem, and compilation managed to be completed!
However, trying to run the resulting executable yielded: "Segmentation fault"
I guess this means that this is a new problem, so should I send a new email?
Indeed, it would be nice if you explain what you did to see if we can
reproduce the problem.
thanks,
Sebastien.
Thanks a lot for the quick answers!
On Jun 20, 2012, at 17:43 PM, Sebastien Loriot (GeometryFactory) wrote:
There is indeed a compatibility problem of CGAL with the version
3.1.0-rc1 of Eigen. We'll fix that.
In the meantime, can you use Eigen 3.1.0-alpha1 which I know is working.
Sorry for the inconvenience.
Sebastien.
On 06/20/2012 05:27 PM, Dror Atariah wrote:
I cleared all the previously generated Cmake related files. Then I ran the
cgal_create_cmake_script and then what you suggested:
"cmake -DEIGEN3_INCLUDE_DIR=/Users/drorata/Library/eigen3.1.0-rc1 ."
This was the output:
---(Output)---
-- The C compiler identification is GNU 4.2.1
-- The CXX compiler identification is GNU 4.2.1
-- Checking whether C compiler has -isysroot
-- Checking whether C compiler has -isysroot - yes
-- Checking whether C compiler supports OSX deployment target flag
-- Checking whether C compiler supports OSX deployment target flag - yes
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Checking whether CXX compiler has -isysroot
-- Checking whether CXX compiler has -isysroot - yes
-- Checking whether CXX compiler supports OSX deployment target flag
-- Checking whether CXX compiler supports OSX deployment target flag - yes
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = '-pipe -O2 -arch x86_64 -frounding-math
-fno-strict-aliasing -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -L/opt/local/lib -arch x86_64
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=10
-- Mac Leopard detected
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
EIGEN3_INCLUDE_DIR
-- Build files have been written to:
/Users/drorata/Documents/academics/programing/CGAL/Surface_reconstruction_points_3_CGAL_4
---(Output END)---
Then trying to compile the example yielded:
---(Output)---
In file included from
/opt/local/include/CGAL/Poisson_reconstruction_function.h:32,
from
/Users/drorata/Documents/academics/programing/CGAL/Surface_reconstruction_points_3_CGAL_4/poisson_reconstruction_example.cpp:10:
/opt/local/include/CGAL/Eigen_solver_traits.h:24:24: error: Eigen/Sparse: No
such file or directory
In file included from /opt/local/include/CGAL/Eigen_solver_traits.h:26,
from
from
/opt/local/include/CGAL/Eigen_vector.h:24:22: error: Eigen/Core: No such file
or directory
...(CONTINUES)
---(Output END)---
This seems not to work.
I don't think that the problem is finding EIGEN. Currently I have (as Michael
Hemmer suggested) the following line in my CMakeLists.txt:
include_directories (BEFORE "~/Library/eigen3.1.0-rc1/")
It seems like neither your suggestion nor setting EIGEN3_INC_DIR to the
eigen's location helps.
Anyway, with either Michael's trick or Menelaos' (which was adding a soft
link to the include directory of the example which pointed to the location of
eigen) it seems like eigen can be found, but the compilation error is always
there.
Dror.
On Jun 20, 2012, at 16:55 PM, Sebastien Loriot (GeometryFactory) wrote:
Try:
There should be no need to do something else for the demo.
This was documented on that page:
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_10.4
Sebastien.
On 06/20/2012 04:19 PM,
wrote:
I have installed *CGAL 4.0* on a Mac OS 10.6 using *macports*. As a test
case, I tried to compile the example given in /Triangulation_2/, using the
standard procedure:
- cgal_create_cmake_script
- cmake .
- make
This worked like a charm and suggests, if I understand it correctly, that
CGAL's installation is OK.
Next, I wanted to compile and consider the example
/Surface_reconstruction_points_3/. Here things got messy. I'll try to
describe the steps I took (some of them with the great help of Menelaos
Karavelas and Michael Hemmer. Thank you Menelaos and MIchael) in order to
resolve the issue.
The version of Eigen shipped with the CGAL installation through macports is
old, and thus I downloaded manually the latest version of eigen (3.1.0-rc1).
In addition, I added the following line to the CMakeLists.txt:
where ~/Library/eigen3.1.0-rc1/ is where the file
"signature_of_eigen3_matrix_library" is located.
This should make sure that eigen will be looked for in the right location.
Then I added
#define CGAL_EIGEN3_ENABLED
to the example "poisson_reconstruction_example.cpp". Finally, I ran:
- cmake .
- make poisson_reconstruction_example
Then I got the following compilation error:
---Compilation Error Cite---
/Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h: In copy
constructor
‘Eigen::IterativeSolverBase<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
0, int>, 1, Eigen::DiagonalPreconditioner<double> >
::IterativeSolverBase(const
0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’:
/Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/IterativeLinearSolvers/
IterativeSolverBase.h:37: instantiated from ‘bool
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function() [with
Gt = CGAL::Epick]’
Surface_reconstruction_points_3_CGAL_4/poisson_reconstruction_example.cpp:65:
instantiated from here
/Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h:113: error:
‘Eigen::internal::noncopyable::noncopyable(const
Eigen::internal::noncopyable&)’ is private
IterativeSolverBase.h:37: error: within this context
ConjugateGradient.h: In copy constructor
‘Eigen::ConjugateGradient<Eigen::SparseMatrix<double, 0, int>, 1,
Eigen::DiagonalPreconditioner<double> >::ConjugateGradient(const
Eigen::DiagonalPreconditioner<double> >&)’:
ConjugateGradient.h:160: instantiated from ‘bool
Gt = CGAL::Epick]’
ConjugateGradient.h:160: note: synthesized method
0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’ first
required here
/opt/local/include/CGAL/Eigen_solver_traits.h: In copy constructor
‘CGAL::Eigen_solver_traits<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
::Eigen_solver_traits(const
/opt/local/include/CGAL/Eigen_solver_traits.h:58: instantiated from ‘bool
Gt = CGAL::Epick]’
/opt/local/include/CGAL/Eigen_solver_traits.h:58: note: synthesized method
Eigen::DiagonalPreconditioner<double> >&)’ first required here
/opt/local/include/CGAL/Poisson_reconstruction_function.h: In member function
‘bool CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function()
[with Gt = CGAL::Epick]’:
/opt/local/include/CGAL/Poisson_reconstruction_function.h:264: note:
synthesized method
required here
make[3]: *** [CMakeFiles/poisson_reconstruction_example.dir/
poisson_reconstruction_example.cpp.o] Error 1
make[2]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2
make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/rule] Error 2
make: *** [poisson_reconstruction_example] Error 2
---Compilation Error END---
I am unable to find what the problem is? Seems like it is either a problem in
EIGEN, or the way it is being using in CGAL/this specific example.
If further details regarding my setting etc. is needed please let me know.
Thanks in advance!
Dror Atariah
PS: I'm in Chapel Hill till tomorrow, so if you're around I'm available to
have a look at the problem together.
